RAK4631 - no programming possible
We have a couple of RAK4631 modules that we are developing a custom board for.
The firmware should be Arduino BSP.
OS is Windows 11 or MacOS X. I have tried both the Arduino IDE toolchain as well as PlatformIO.
We soldered a pinheader to the five connectors (3V3, SWDIO, SWCLK, GND, RESET) directly on the board. We tried a Segger J-Link and two ST-Links, but no SWD connection was possible.
Regarding the pinout, I followed WisBlock/bootloader/RAK4630 at master · RAKWireless/WisBlock · GitHub (note though: VCC is 5V on the J-Link, therefore I did not use that connection and instead connected an external 3V3 power supply.
J-Link>Device nRF52840_xxAA
J-Link>Speed 1000
Selecting 1000 kHz as target interface speed
J-Link>Connect
Please specify target interface:
J) JTAG (Default)
S) SWD
T) cJTAG
TIF>S
Device “NRF52840_XXAA” selected.
Connecting to target via SWD
InitTarget() start
InitTarget() end - Took 103ms
Found SW-DP with ID 0x2BA01477
DPIDR: 0x2BA01477
CoreSight SoC-400 or earlier
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011, ADDR: 0x00000000)
AP[1]: JTAG-AP (IDR: 0x02880000, ADDR: 0x01000000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
Found Cortex-M4 r0p1, Little endian.
FPUnit: 6 code (BP) slots and 2 literal slots
CoreSight components:
ROMTbl[0] @ E00FF000
[0][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
[0][1]: E0001000 CID B105E00D PID 003BB002 DWT
[0][2]: E0002000 CID B105E00D PID 002BB003 FPB
[0][3]: E0000000 CID B105E00D PID 003BB001 ITM
[0][4]: E0040000 CID B105900D PID 000BB9A1 TPIU
[0][5]: E0041000 CID B105900D PID 000BB925 ETM
Memory zones:
Zone: “Default” Description: Default access mode
Cortex-M4 identified.
J-Link>Erase
No address range specified, ‘Erase Chip’ will be executed
‘erase’: Performing implicit reset & halt of MCU.
Reset type: NORMAL (J-Link Reset Strategies - SEGGER Knowledge Base)
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Reset: SYSRESETREQ has confused core.
DPIDR: 0x2BA01477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set, ADDR: 0x00000000)
AP[0]: Core found
Reset: Using fallback: VECTRESET.
Reset: Reset device via AIRCR.VECTRESET.
Erasing device…
J-Link: Flash download: Only internal flash banks will be erased.
To enable erasing of other flash banks like QSPI or CFI, it needs to be enabled via > “exec EnableEraseAllFlashBanks”
J-Link: Flash download: Total time needed: 0.348s (Prepare: 0.279s, Compare: > 0.000s, Erase: 0.068s, Program: 0.000s, Verify: 0.000s, Restore: 0.000s)
ERROR: Erase returned with error code -5.
All similar attempts with i.e. nrfjprog --log --family nRF52 --eraseall failed.
What are we doing wrong?
That is NOT a supply voltage, it is a voltage sense input.
3.3V alone is not sufficient to power up the RAK4631, you need Vdd and VBat to get the MCU to work and be available on the SWD.
For a RAK4631, the best solution is to keep it on a Base Board and supply it through the USB connector.
This answered confirmed what I thought from using the RAKDAP1 on multiple cores when I would get them locked up in boot mode and couldn’t use reset, etc. I also found that USB first was recommended after RAKDAP1 was connected to core. ( I also solder pins to all my cores - and baseboards.) I found the RAKDAP1 Quick Start and other documents most helpful for my RAK4631 cores.
