RAK4631 Arduino BSP
Unable check firmware but The problem occurs on all 10 devices I have
Computer with MacOS - Sonoma 14.3 The problem also occurs on earlier versions of the system
Each time I connect the device to the USB port, the system does not show the CU.USBMODEM device. After a full restart of the computer, the device is visible for a few seconds and then disappears. Any further steps (Arduino, make, or other techniques) will probably be possible after solving this problem.
ARDUINO IDE - it is installed and configured - of course it does not see the device either.
I’m guessing that some driver is missing… the question is which one.
I have no Apple M2 to test but it seems the driver is being restricted to execute when it shows then disappear. Added to that is that it happens to all modules. If you double click reset button, does anything happen (assuming you are using WisBlock Baseboard)?
Few ideas I have:
Install Arduino Legacy 1.8.x if you have the latest Arduino 2.x and see if it has any effect.
Check if macos folder is present and has the nrfutil inside it. This should be in your Arduino installation.
