RAK4631 + rak19007 + rak5860 deep sleep
  • What product do you wish to discuss? RAK4631, RAK19007, RAK5860, + fram modeule and RTC module
Using Arduino BSP how do I put the RAK4631 to sleep? I need it to wake on a timer or an external interrupt.
I read in another post that the lora modeule had to be initialised to allow the MCU to go to sleep:
|  |// We are not using LoRa here|
||// But to keep power consumption low we need|
||// to initialize the radio|
||lora_rak4630_init();|
||// And send it to sleep mode|
||Radio.Sleep();|
However, I find I am still using 9.4mA at idle and using delay or semaphores dont make a difference
As long as you do not use FreeRTOS functions and let the device run endless in your loop() function you will never get the power down.
I am using semaphores to wake up the device based on timer or external interrupts. Have a look into my Low-Power code example.
The timer-controlled wake-up from deep sleep is one part.
Do I have to use the PSM mode of BG77 during this time to reduce the power consumption of the modem, too?
