I have a WisBlock RAK4631 assembly with GPS module RAK12500.
Software loaded is Mashtastic 2.5.18. (This is my third RAK4631 assembly) In Settings/Device/ Heartbeat LED(green) is turned off. Assembly consists of 19007/4630/1921 modules
The issue I am facing is that after booting up cold board (powered by USB-C (5.2VDC) all works well for about 4-6 minutes.
Then the board turns off, looks to be asleep as the red LED blinks at a .6 second rate mostly and Bluetooth connection drops and will not reconnect. Just before it shuts down the green LED starts to blink rapidly for about a second then the current drops to zero. 30-90 seconds before the green LED starts to blink and the system goes to sleep the current intermittently drops to zero many times. The red LED then blinks slowly at .6secs with random burst both very dimly with current at zero (below what I can measure) Now and then there is a current flow of about 0.03A… The assembly never wakes up. If the reset button is pressed the system boots and works normally for about 60-110 seconds then the process starts over again and it goes to sleep.
This does not happen with display or no display connected without the GPS module connected. Only when the GPS module is connected.
I have looked to see if there is some setting (like go to sleep in X seconds) but have not seen such.
These are new parts just delivered in the last few weeks and this is the first assembly and programming. Using Win11 I have also done an erase (file for 6.1.1) and reprogramming three times (using the Meshtastic flash app).
Current: @5.22VDC
First cold boot:
Receive 0.05A-0.07A mostly 0.06A
Transmit 0.17A-0.21A mostly 0.18A
After pressing reset the current is lower that after a good boot: 0.03-0.06A mostly 0.03A
So looks to be the GPS module unless I am missing something.
Forgive the prattling on but wanted to give as much info as possible.
Anyone have any ideas? Thanks
Edit:
Is it normal to have the red LED flashing all the time?
My new RAK Pocket V2, which is the same board, does not do this but this board does…
