Hi - I’ve been playing around with my RAK4631 on a RAK19003 for a few days trying to get it to connect to my ChripstackOS system (a RAK 7248P running full ChripstackOS since the build script is still broken) and have been unable to get an OTAA to happen successfully. Ive been using numerous different methods from my own Arduino scripts implementing methods to the LoRaWAN_OTAA_ABP example. Each time I get
Welcome to RAK4630 LoRaWan!!!
Type: OTAA
Region: US915
OTAA join failed!
Check your EUI’s and Keys’s!
Check if a Gateway is in range!
Ive validated my Keys numerous times, and scanned every thread I can find on this topic and none have come to any resolution. Chirpstack is picking up frames from the gateway so I know it’s receiving as expected. I’ve played around with all the different possible bands including just using non-us bands to see if it will work (dont tell the FCC).
Here is my code im running on the device deployed via Arduino:
* @file LoRaWAN_OTAA_ABP.ino
* @author rakwireless.com
* @brief LoRaWan node example with OTAA/ABP registration
* @version 0.1
* @date 2020-08-21
* @copyright Copyright (c) 2020
* @note RAK4631 GPIO mapping to nRF52840 GPIO ports
RAK4631 <-> nRF52840
WB_IO1 <-> P0.17 (GPIO 17)
WB_IO2 <-> P1.02 (GPIO 34)
WB_IO3 <-> P0.21 (GPIO 21)
WB_IO4 <-> P0.04 (GPIO 4)
WB_IO5 <-> P0.09 (GPIO 9)
WB_IO6 <-> P0.10 (GPIO 10)
WB_SW1 <-> P0.01 (GPIO 1)
WB_A0 <-> P0.04/AIN2 (AnalogIn A2)
WB_A1 <-> P0.31/AIN7 (AnalogIn A7)
#include <Arduino.h>
#include <SPI.h>
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
#define LORAWAN_DATERATE DR_0 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_5 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
DeviceClass_t g_CurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_US915; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_UNCONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] = {0xAC,0x1F,0x09,0xFF,0xFE,0x1B,0x7C,0xCE};
uint8_t nodeAppEUI[8] = {0x59,0x8B,0x55,0x80,0x74,0xC2,0xFB,0xE1};
uint8_t nodeAppKey[16] = {0x20,0x2e,0xDF,0x9F,0x56,0x1C,0x78,0xB1,0x3E,0x92,0xD8,0xAD,0x6E,0x67,0xEC,0x39};
// ABP keys
uint32_t nodeDevAddr = 0x260116F8;
uint8_t nodeNwsKey[16] = {0x7E, 0xAC, 0xE2, 0x55, 0xB8, 0xA5, 0xE2, 0x69, 0x91, 0x51, 0x96, 0x06, 0x47, 0x56, 0x9D, 0x23};
uint8_t nodeAppsKey[16] = {0xFB, 0xAC, 0xB6, 0x47, 0xF3, 0x58, 0x45, 0xC7, 0x50, 0x7D, 0xBF, 0x16, 0x8B, 0xA8, 0xC1, 0x7C};
// Private defination
#define LORAWAN_APP_INTERVAL 20000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
void setup()
pinMode(LED_BUILTIN, OUTPUT);
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
// Initialize LoRa chip.
lora_rak4630_init();
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_CN779:
Serial.println("Region: CN779");
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
case LORAMAC_REGION_RU864:
Serial.println("Region: RU864");
break;
case LORAMAC_REGION_AS923_2:
Serial.println("Region: AS923-2");
break;
case LORAMAC_REGION_AS923_3:
Serial.println("Region: AS923-3");
break;
case LORAMAC_REGION_AS923_4:
Serial.println("Region: AS923-4");
break;
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
return;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
if (err_code != 0)
return;
// Start Join procedure
lmh_join();
void loop()
// Put your application tasks here, like reading of sensors,
// Controlling actuators and/or other functions.
/**@brief LoRa function for handling HasJoined event.
if(doOTAA == true)
else
Serial.println("ABP Mode");
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
* @param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
//Not joined, try again later
return;
uint32_t i = 0;
m_lora_app_data.buffer[i++] = 'H';
m_lora_app_data.buffer[i++] = 'e';
m_lora_app_data.buffer[i++] = 'l';
m_lora_app_data.buffer[i++] = 'o';
m_lora_app_data.buffer[i++] = '!';
m_lora_app_data.buffsize = i;
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/**@brief Function for handling user timerout event.
send_lora_frame();
* @details Initializes the timer module. This creates and starts application timers.
return 0;
Here are my configs in Chripstack:
Ive also reviewed the documentation here to see if it could guide me but cannot replicate. WisBlock/examples/RAK4630/communications/LoRa/LoRaWAN at master · RAKWireless/WisBlock · GitHub
Does anyone have any ideas?
