- What product do you wish to discuss? — RAK4631
- What firmware are you using? ---------- Arduino BSP
@beegee
I want know does RAK4631 has an option for watchdog? If yes kindly help me out to implement or give example code.
I am not aware of a watchdog function in the nRF52840/RAK4631
Hello @RaviKM
RAK4631 is based on nrf52840, so basically you can use all its resources, including a hardware WDT. I don’t know if Arduino BPS includes an easy way to set WDT up, but here is an example of how to do it using MCU registers:
#include <nrf52840.h>
//Call this when you are configuring your device (like in setup())
void setupWDT(void) {
//Configure Hardware WDT.
NRF_WDT->CONFIG = 0x01; // Configure WDT to run when CPU is asleep
NRF_WDT->CRV = 3932159; // Timeout set to 120 seconds, timeout[s] = (CRV-1)/32768
NRF_WDT->RREN = 0x01; // Enable the RR[0] reload register
NRF_WDT->TASKS_START = 1; // Start WDT
//Feed WDT frencuently enough to avoid WDT trigger
void feedWDT(void) {
NRF_WDT->RR[0] = WDT_RR_RR_Reload;
Cheers
