What is the actual nRF82540 pinouts used for the
The circuit diagrams do not show the connection to the nRF82540 soc ?
Is there more complete circuit diagrams available ?
- RAK5005-O
- RAK4361
- RAK14000 e-paper
- RAK13002
Hello @mark.birss , welcome to the forum.
As there are many modules, we do not have a connection diagram for each single combination.
WisBlock Core to WisBlock IO slot is 1-to-1 the same
And the WisBlock Core to WisBlock Slot A/B/C/D is like this
When writing your code with ArduinoIDE, you have the IO’s defined in the variant.h file
* WisBlock Base GPIO definitions
static const uint8_t WB_IO1 = 17; // SLOT_A SLOT_B
static const uint8_t WB_IO2 = 34; // SLOT_A SLOT_B
static const uint8_t WB_IO3 = 21; // SLOT_C
static const uint8_t WB_IO4 = 4; // SLOT_C
static const uint8_t WB_IO5 = 9; // SLOT_D
static const uint8_t WB_IO6 = 10; // SLOT_D
static const uint8_t WB_SW1 = 33; // IO_SLOT
static const uint8_t WB_A0 = 5; // IO_SLOT
static const uint8_t WB_A1 = 31; // IO_SLOT
static const uint8_t WB_I2C1_SDA = 13; // SENSOR_SLOT IO_SLOT
static const uint8_t WB_I2C1_SCL = 14; // SENSOR_SLOT IO_SLOT
static const uint8_t WB_I2C2_SDA = 24; // IO_SLOT
static const uint8_t WB_I2C2_SCL = 25; // IO_SLOT
static const uint8_t WB_SPI_CS = 26; // IO_SLOT
static const uint8_t WB_SPI_CLK = 3; // IO_SLOT
static const uint8_t WB_SPI_MISO = 29; // IO_SLOT
static const uint8_t WB_SPI_MOSI = 30; // IO_SLOT
// Number of pins defined in PinDescription array
#define PINS_COUNT (48)
#define NUM_DIGITAL_PINS (48)
#define NUM_ANALOG_INPUTS (6)
#define NUM_ANALOG_OUTPUTS (0)
// LEDs
#define PIN_LED1 (35)
#define PIN_LED2 (36)
#define LED_BUILTIN PIN_LED1
#define LED_CONN PIN_LED2
#define LED_GREEN PIN_LED1
#define LED_BLUE PIN_LED2
Thank you, I just saw this also with your recent bootlaoder update
