Issue:
On a single RAK5010 with the Quectel BG95-M3 modem, stock firmware (at+version = RUI v3.0.0.15), the modem registers fine but any operation that actually uses the cellular data path fails and reboots the device. Registration, signal and IP assignment are all fine; context activation / opening a socket / sending are not.
Setup:
- RAK5010, Quectel BG95-M3 modem, stock firmware RUI v3.0.0.15
- SIM: 1NCE, APN
iot.1nce.net, no user/pass - Network: registers automatically on Vodafone NL LTE-M (
+COPS: 0,0,"vodafone NL",8) - Powered from USB and a fully charged LiPo at the same time (battery 4.1 V)
- Serial console with the DTR/DSR settings from the docs, 115200
- Goal: use the built-in cellular tracker loop (
cellular:send_interval) to send GPS + sensor data to my own TCP server (server confirmed reachable from the internet)
Details:
What works:
+CSQ: 26,99+CGATT: 1+CGPADDR: 1,100.65.x.x(gets an IP)- sensors and battery read fine
What fails:
The board powers off completely during cellular commands — no LED, USB serial does not re-enumerate, I have to unplug both USB and the LiPo to recover it. This happens even on
at+set_config=cellular:(AT+QICSGP=1), which is only a query.at+scan=cellularalso reboots the device. -
Manual send fails. After
at+set_config=cellular:<ip>:<port>:a:a:iot.1nce.net:8, the commandat+send=cellular:test123returns+QIOPEN: 0,567(socket has been closed), throwsERRORplus some garbage bytes, and reboots (APP RDY). Nothing arrives at my server. -
The tracker loop never connects. With
send_interval:1:150000set and the device outside for 20+ minutes, it never opens a connection to my server, and never gets a GPS fix. -
Long AT commands get truncated. The
cellular:<ip>:<port>:<op>:<op>:<apn>:<net>line loses everything after a space in a field, and drops trailing characters if the whole line is longer than ~60 chars. I only got the full command (with the:8net type) to register after shortening the operator fields to single letters.
- Is this a known problem with RUI v3.0.0.15 on the BG95-M3 units?
- Is there a newer firmware, and can I flash it without an SWD probe (BLE DFU, USB, or the RAK Serial Port Tool)?
- Does the tracker loop require a GPS fix before it transmits anything?
- Is there a supported way to read back the stored
cellular:config? (at+get_config=cellular:returnsERROR:RUI_AT_UNSUPPORT 1.)
Happy to post full serial logs.
