My assistance data is up to date and I tested differents files (several path for xtra2.bin and xtra3grc.bin).
Also, I get a position when I am registered with GSM networks but not with LTE networks.
Actually 5010 just transmits the AT to bg96, and there is no CAT M1 in our test environment. So maybe you can consult quectel directly on their forum. Query whether the network effect gnss or not.
Also, could you tell me, how long do you have to wait after power up for a position fix in your test environment?
And what url do you use for it? (I use http://xtrapath8.izatcloud.net/xtra3grc.bin)
Hi, I would like to use gpsOneXTRA Assistance, and I’m not sure how to load the .bin file into the modem, because the data sheet says: “store the valid gpsOneXTRA data file in RAM or UFS (RAM recommended)” but I’m not sure what steps to take to store it in RAM. I hope you can help me.
Thank you very much.
Once I have downloaded that file I add it to RAK5010_dfu.zip? That .zip file (compiled project) is the one I send by bluetooth through the nrf app to program the board. I mean, I don’t know exactly where to save the .bin file so that it can be executed from the board
+QHTTPGET: <err>[,<httprspcode>[,<content_length>]] AT+QHTTPREADFILE=“UFS:xtra3grc.bin”,80 OK AT+QGPSXTRATIME=0,“2020/06/03,20:13:00”,1,1,120000 //change with current time OK AT+QGPSXTRADATA=“UFS:xtra3grc.bin” OK
