Issue: GPS not working
Setup: RAK5010 with Lithium Battery
Details: The RAK5010 can power the GPS antenna … if the GPS antenna is replugged with the power on then there the possibility of shorting to ground from the schematic it appears there is no current limiting by the GPS ant power switch mosfet. This is unfortunate as the design could have incorporated current limiting or resettable fusing as the antenna only draws 10 ma or am I wrong … ?
