I can’t change the GPS format.
Of the 3 formats, I want to use the (format: (-) dd.ddddd, (-) ddd.ddddd) display.
You can’t switch from the AT command, or at least I don’t know about it.
I saw that the RAK5205 has an AT command for this.
at + set_config = device: gps_format: X
Is there a solution for this from the AT command on the RAK5010?
Or can you change the firmware so that the query is in (2) format?
The current format, (1) can be interpreted by few sources.
(Lat: 4517.112343, Lon: 1823.707123)
Much more manageable and better known (2)
Lat: 45.237612, Lon: 18.224563
Does anyone know a solution for this?
Thanks in advance.
