Issue: After trying to send periodically my RAK5010 hangs. After reboot by power up at+version works sometimes. But no further command.
I tried AT&F after a new power-up w/o success.
What can I do?
What can I do?
Hi @ckuehnel ,
I believe you have the same situation here.
When you enable the autosend (periodic), the module will automatically goes to sleep. You have a small window to be able to communicate with it. If further configuration is needed, you can disable it for the meantime.
Yes, I think you are right. You should mention this in the documentation. Now it works again. May be I found the small slot to diasable this Option.
