Issue: GPS readout almost always 0, 0
Setup: RAK5010-M connected via micro-USB to host. Connected LTE, GPS antennas, and 5V power supply. Using Termite to send commands.
Details: I plug the board into my computer and wait for the solid blue LED and a flashing red LED. Then I connect with Termite. I send commands and receive the outputs as follows:
input:
at+version
output:
at+version
Firmware Version: RUI v3.0.0.15
OK
input:
at+set_config=device:gps:1
output:
OK
input:
at+get_config=device:status
output:
Acc:-184.00,3.00,919.00; Tem:31.16;Hum:47.18; Lat(0-N,1-S):1,0.000000,Lon(0-E,1-W):1,0.000000;
OK
Most of the time, the latitude and longitude readings are 0 as above. I wait several minutes, and sometimes close to an hour, and still the readout is 0. It’s when I wait several hours that I get a correct GPS reading. How do I fix this?
