We are experimenting with the RAK5010 using v3.15 firmware.
The device is being very troublesome/unreliable and I’m not sure where to start troubleshooting this. I have managed to connect it successfully to LTE and send data to our server. I leave this and it can last anywhere from a few hours to a day, periodically sending data (as per the send_interval command).
After that, it simply stops and it appears as if the network connection has been completely broken. Also, the BG96 commands simply become very unresponsive.
As you can see here I have tried to run some simple status commands, and then the scan command, and the scan just hangs totally and never retrieves a result.
As mentioned, scan has previously picked up my network and connected to it correctly - but now it is just totally stopped. How can I debug this?
