Now I’ve purchased the Gateway Developer solution which include Rpi HAT and RAK5146 for KR920. My order number was #62995.
After wasting for trying to set up udp-packet-forwarder, I found a critical error in 5146 firmware. With BAND option ‘kr_920_923’, following log was displayed.
(previous log omitted)…
udp-packet-forwarder | INFO: upstream port is configured to “1700”
udp-packet-forwarder | INFO: downstream port is configured to “1700”
udp-packet-forwarder | INFO: packets received with a valid CRC will be forwarded
udp-packet-forwarder | INFO: packets received with a CRC error will NOT be forwarded
udp-packet-forwarder | INFO: packets received with no CRC will NOT be forwarded
udp-packet-forwarder | INFO: GPS serial port path is configured to “/dev/ttyAMA0”
udp-packet-forwarder | INFO: Reference latitude is configured to 0.000000 deg
udp-packet-forwarder | INFO: Reference longitude is configured to 0.000000 deg
udp-packet-forwarder | INFO: Reference altitude is configured to 0 meters
udp-packet-forwarder | INFO: fake GPS is disabled
udp-packet-forwarder | This is uart for GPS.
udp-packet-forwarder | INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
udp-packet-forwarder | Opening SPI communication interface
udp-packet-forwarder | Note: chip version is 0x12 (v1.2)
udp-packet-forwarder | INFO: using legacy timestamp
udp-packet-forwarder | ARB: dual demodulation disabled for all SF
udp-packet-forwarder | ERROR: sx1261_com_open: Failed to connect to sx1261 radio on
udp-packet-forwarder | ERROR: failed to connect to the sx1261 radio (LBT/Spectral Scan)
udp-packet-forwarder | ERROR: [main] failed to start the concentrator
(stopped)
But just only changing BAND option to ‘eu_863_870’ which is the default, It worked properly with following log
udp-packet-forwarder | INFO: LoRa Service modem: configuring preamble size to 8 symbols
udp-packet-forwarder | INFO: [main] concentrator started, packet can now be received
udp-packet-forwarder | INFO: concentrator EUI: 0x0016c001ff1dfaa2
udp-packet-forwarder | WARNING: [gps] GPS out of sync, keeping previous time reference
udp-packet-forwarder | INFO: [down] PULL_ACK received in 277 ms
udp-packet-forwarder | INFO: [modify_os_time] local_time=1666951381, gps_time=1666951380
udp-packet-forwarder | INFO: [modify_os_time] The difference between the system time(1666951381) and the GPS time(1666951380) is less than 10 seconds. Use the system time.
udp-packet-forwarder | INFO: [down] PULL_ACK received in 275 ms
udp-packet-forwarder | ##### 2022-10-28 10:03:30 GMT #####
udp-packet-forwarder | ### [UPSTREAM] ###
udp-packet-forwarder | # RF packets received by concentrator: 0
(next logs omitted…, permanently alive)
please update firmware and send me with the information for upgrading firmware
