I have 2 RAK5146 concentrators in a RAK7391 server. I am using the UDP packet forwarder as I need the GPS location. I am running 2 UDP packet forwarders to make use of the 2 RAK5146’s installed. The configuration for packet forwarder 1 is as follows:
version: '2.0'
services:
udp-packet-forwarder:
image: rakwireless/udp-packet-forwarder:latest
container_name: udp-packet-forwarder-c1
restart: unless-stopped
privileged: true
network_mode: host
# volumes:
# - ./global_conf.json:/app/global_conf.json:ro
environment:
SERVER_HOST: localhost
MODEL: "RAK5146"
INTERFACE: "USB"
HAS_GPS: 1
RADIO_DEV: "/dev/ttyACM1"
GPS_DEV: "/dev/ttyAMA0"
GATEWAY_EUI_SOURCE: "chip"
The configuration of rhte second packet forwarder is as follows:
version: '2.0'
services:
container_name: udp-packet-forwarder-c2
privileged: true
network_mode: host
# volumes:
environment:
MODEL: "RAK5146"
HAS_GPS: 0
RESET_GPIO: 0
GATEWAY_EUI: "0016c001ff1e54b3"
RADIO_DEV: "/dev/ttyACM2"
However, both the packet forwarders wants to access the GPS on /dev/ttyAMA0. As a result I am getting the warning on both packet forwarders (only one log shown):
udp-packet-forwarder-c2 | WARNING: [gps] could not get a valid message from GPS (no time)
Why ido both packet forwarders want to access the GPS even though it is disabled in the one? How can a prevent one of the packet forwarders from trying to access the GPS device?
Any help or suggestions would be helpfull
