Hi everyone,
I’m currently working with both ChirpStack V4 and the UDP Packet Forwarder, running them in containerized environments. I’ve encountered an issue where the logs repeatedly show the message: no valid GPS coordinates available yet.
✔ Container udp-packet-forwarder Recreated 0.1s
Attaching to udp-packet-forwarder
udp-packet-forwarder | ------------------------------------------------------------------
udp-packet-forwarder | UDP Packet Forwarder Container v2.4.6
udp-packet-forwarder | (c) RAKWireless 2022-2024
udp-packet-forwarder | Based on:
udp-packet-forwarder | * lora_gateway v5.0.1
udp-packet-forwarder | * packet_forwarder v4.0.1
udp-packet-forwarder | * sx1302_hal v2.1.0
udp-packet-forwarder | * picoGW_hal v0.2.3
udp-packet-forwarder | * picoGW_packet_forwarder v0.1.0
udp-packet-forwarder | * gateway_2g4_hal v1.1.0
udp-packet-forwarder | Protocol
udp-packet-forwarder | Mode: DYNAMIC
udp-packet-forwarder | Protocol: UDP
udp-packet-forwarder | Server: localhost:1700
udp-packet-forwarder | Band: eu_863_870
udp-packet-forwarder | Gateway EUI: D83ADDFFFE37A116
udp-packet-forwarder | EUI Source: eth0
udp-packet-forwarder | Radio
udp-packet-forwarder | Model: RAK5146
udp-packet-forwarder | Concentrator: SX1303
udp-packet-forwarder | Design: CORECELL
udp-packet-forwarder | Interface: USB
udp-packet-forwarder | Radio Device: /dev/ttyACM0
udp-packet-forwarder | Extra
udp-packet-forwarder | Stat interval: 10
udp-packet-forwarder | Push timeout: 100
udp-packet-forwarder | GPS Device: /dev/ttyAMA0
udp-packet-forwarder | Use fake GPS: FALSE
udp-packet-forwarder | *** Packet Forwarder ***
udp-packet-forwarder | Version: 2.1.0
udp-packet-forwarder | *** SX1302 HAL library version info ***
udp-packet-forwarder | Version: 2.1.0;
udp-packet-forwarder | INFO: Little endian host
udp-packet-forwarder | INFO: found configuration file global_conf.json, parsing it
udp-packet-forwarder | INFO: global_conf.json does contain a JSON object named SX130x_conf, parsing SX1302 parameters
udp-packet-forwarder | INFO: com_type USB, com_path /dev/ttyACM0, lorawan_public 1, clksrc 0, full_duplex 0
udp-packet-forwarder | INFO: antenna_gain 0 dBi
udp-packet-forwarder | INFO: Configuring legacy timestamp
udp-packet-forwarder | INFO: SX1261 spi_path is not configured in global_conf.json
udp-packet-forwarder | INFO: Configuring Tx Gain LUT for rf_chain 0 with 16 indexes for sx1250
udp-packet-forwarder | INFO: radio 0 enabled (type SX1250), center frequency 867500000, RSSI offset -215.399994, tx enabled 1, single input mode 0
udp-packet-forwarder | INFO: radio 1 enabled (type SX1250), center frequency 868500000, RSSI offset -215.399994, tx enabled 0, single input mode 0
udp-packet-forwarder | INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 5 to 12
udp-packet-forwarder | INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7, Explicit header
udp-packet-forwarder | INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
udp-packet-forwarder | INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
udp-packet-forwarder | INFO: gateway MAC address is configured to D83ADDFFFE37A116
udp-packet-forwarder | INFO: server hostname or IP address is configured to "localhost"
udp-packet-forwarder | INFO: upstream port is configured to "1700"
udp-packet-forwarder | INFO: downstream port is configured to "1700"
udp-packet-forwarder | INFO: downstream keep-alive interval is configured to 10 seconds
udp-packet-forwarder | INFO: statistics display interval is configured to 10 seconds
udp-packet-forwarder | INFO: upstream PUSH_DATA time-out is configured to 100 ms
udp-packet-forwarder | INFO: packets received with a valid CRC will be forwarded
udp-packet-forwarder | INFO: packets received with a CRC error will NOT be forwarded
udp-packet-forwarder | INFO: packets received with no CRC will NOT be forwarded
udp-packet-forwarder | INFO: GPS serial port path is configured to "/dev/ttyAMA0"
udp-packet-forwarder | INFO: Reference latitude is configured to 0.000000 deg
udp-packet-forwarder | INFO: Reference longitude is configured to 0.000000 deg
udp-packet-forwarder | INFO: Reference altitude is configured to 0 meters
udp-packet-forwarder | INFO: Beaconing period is configured to 0 seconds
udp-packet-forwarder | INFO: Beaconing signal will be emitted at 869525000 Hz
udp-packet-forwarder | INFO: Beaconing channel number is set to 1
udp-packet-forwarder | INFO: Beaconing channel frequency step is set to 0Hz
udp-packet-forwarder | INFO: Beaconing datarate is set to SF9
udp-packet-forwarder | INFO: Beaconing modulation bandwidth is set to 125000Hz
udp-packet-forwarder | INFO: Beaconing TX power is set to 27dBm
udp-packet-forwarder | INFO: global_conf.json does contain a JSON object named debug_conf, parsing debug parameters
udp-packet-forwarder | INFO: got 2 debug reference payload
udp-packet-forwarder | INFO: reference payload ID 0 is 0xCAFE1234
udp-packet-forwarder | INFO: reference payload ID 1 is 0xCAFE2345
udp-packet-forwarder | INFO: setting debug log file name to loragw_hal.log
udp-packet-forwarder | INFO: found configuration file local_conf.json, parsing it
udp-packet-forwarder | INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
udp-packet-forwarder | INFO: fake GPS is disabled
udp-packet-forwarder | This is uart for GPS.
udp-packet-forwarder | INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
udp-packet-forwarder | INFO: [main] concentrator started, packet can now be received
udp-packet-forwarder | INFO: concentrator EUI: 0x0016c001f1563b2e
udp-packet-forwarder | INFO: [down] PULL_ACK received in 0 ms
udp-packet-forwarder | INFO: [up] payload (29 bytes): 40AD32440080CDE9056344D66B4B4AEA1EE93C23B1D93DC2383963240B
udp-packet-forwarder | INFO: [up] pkt from mote: 0x004432AD (netid=0x000000, fcnt=59853)
udp-packet-forwarder | JSON up: {"rxpk":[{"jver":1,"tmst":6678430,"chan":2,"rfch":1,"freq":868.500000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","rssis":-68,"lsnr":10.0,"foff":12687,"rssi":-67,"size":29,"data":"QK0yRACAzekFY0TWa0tK6h7pPCOx2T3CODljJAs="}]}
udp-packet-forwarder | INFO: [up] PUSH_ACK received in 1 ms
udp-packet-forwarder | ##### 2024-08-02 13:19:46 GMT #####
udp-packet-forwarder | ### [UPSTREAM] ###
udp-packet-forwarder | # RF packets received by concentrator: 1
udp-packet-forwarder | # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
udp-packet-forwarder | # RF packets forwarded: 1 (29 bytes)
udp-packet-forwarder | # PUSH_DATA datagrams sent: 1 (255 bytes)
udp-packet-forwarder | # PUSH_DATA acknowledged: 100.00%
udp-packet-forwarder | ### [DOWNSTREAM] ###
udp-packet-forwarder | # PULL_DATA sent: 1 (100.00% acknowledged)
udp-packet-forwarder | # PULL_RESP(onse) datagrams received: 0 (0 bytes)
udp-packet-forwarder | # RF packets sent to concentrator: 0 (0 bytes)
udp-packet-forwarder | # TX errors: 0
udp-packet-forwarder | ### SX1302 Status ###
udp-packet-forwarder | # SX1302 counter (INST): 11119576
udp-packet-forwarder | # SX1302 counter (PPS): 0
udp-packet-forwarder | # BEACON queued: 0
udp-packet-forwarder | # BEACON sent so far: 0
udp-packet-forwarder | # BEACON rejected: 0
udp-packet-forwarder | ### [JIT] ###
udp-packet-forwarder | src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
udp-packet-forwarder | #--------
udp-packet-forwarder | ### [GPS] ###
udp-packet-forwarder | # Invalid time reference (age: 1722604786 sec)
udp-packet-forwarder | # no valid GPS coordinates available yet
udp-packet-forwarder | ##### END #####
udp-packet-forwarder | JSON up: {"stat":{"time":"2024-08-02 13:19:46 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":100.0,"dwnb":0,"txnb":0,"temp":30.0}}
udp-packet-forwarder | INFO: [up] payload (15 bytes): 405BB78300806DD405EBD002F37913
udp-packet-forwarder | INFO: [up] pkt from mote: 0x0083B75B (netid=0x000000, fcnt=54381)
udp-packet-forwarder | JSON up: {"rxpk":[{"jver":1,"tmst":12330855,"chan":2,"rfch":1,"freq":868.500000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","rssis":-35,"lsnr":9.2,"foff":12199,"rssi":-35,"size":15,"data":"QFu3gwCAbdQF69AC83kT"}]}
udp-packet-forwarder | INFO: [up] PUSH_ACK received in 2 ms
udp-packet-forwarder | JSON up: {"rxpk":[{"jver":1,"tmst":13382171,"chan":2,"rfch":1,"freq":868.500000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","rssis":-68,"lsnr":10.8,"foff":12687,"rssi":-68,"size":29,"data":"QK0yRACAzekFY0TWa0tK6h7pPCOx2T3CODljJAs="}]}
udp-packet-forwarder | INFO: [up] PUSH_ACK received in 0 ms
udp-packet-forwarder | ##### 2024-08-02 13:19:56 GMT #####
udp-packet-forwarder | # RF packets received by concentrator: 2
udp-packet-forwarder | # RF packets forwarded: 2 (44 bytes)
udp-packet-forwarder | # PUSH_DATA datagrams sent: 3 (616 bytes)
udp-packet-forwarder | # SX1302 counter (INST): 21129650
udp-packet-forwarder | # Invalid time reference (age: 1722604796 sec)
udp-packet-forwarder | INFO: [down] PULL_ACK received in 1 ms
udp-packet-forwarder | JSON up: {"stat":{"time":"2024-08-02 13:19:56 GMT","rxnb":2,"rxok":2,"rxfw":2,"ackr":100.0,"dwnb":0,"txnb":0,"temp":30.0}}
udp-packet-forwarder | INFO: [up] payload (29 bytes): 40088C8600809CEE05423EA325F23B733B864884BB91C9155E51ECBC2B
udp-packet-forwarder | INFO: [up] pkt from mote: 0x00868C08 (netid=0x000000, fcnt=61084)
Below is docker-compose.yml for udp packet forwarder.
version: '2'
services:
udp-packet-forwarder:
image: rakwireless/udp-packet-forwarder:latest
container_name: udp-packet-forwarder
restart: unless-stopped
privileged: true # set this to true or define the required devices to share with the container under the `devices` tag below
network_mode: host # required to read host interface MAC instead of virtual one, you don't need this if you set the GATEWAY_EUI manually
devices:
- /dev/ttyACM0
environment:
MODEL: "RAK5146"
INTERFACE: "USB"
DEVICE: "/dev/ttyACM0"
GATEWAY_EUI_SOURCE: "AC1F09FFFE0CCF97"
SERVER_HOST: localhost
SERVER_PORT: 1700
HAS_GPS: "1"
GPS_DEV: "/dev/ttyAMA0"
STAT_INTERVAL: 10
I am using RPi CM4 Lite with Intel WiFi6 AX210 PCIe Module and RAK5146 Module with below internal view for modules assembly.
My Setup:
- ChirpStack V4 is being used.
- Hardware: Raspberry Pi Compute Module 4 (RPi CM4).
- GPS Configuration: I have connected Ublox GPS antenna outside the window where I can see from my mobile multiple satellites available.
What I’ve Tried:
- Ensured the GPS module is connected properly and functioning.
- Checked the serial port settings and permissions.
- Verified that the GPS data can be read outside the container.
Questions:
- Has anyone faced a similar issue where the packet forwarder does not receive valid GPS coordinates?
- What steps should I take to diagnose and resolve this problem?
- Are there specific configurations or dependencies I might be overlooking?
Any guidance or suggestions would be greatly appreciated!
Thanks in advance!
