RAK5146 Pi3 gateway makes repeated attempts to connect to TTN but always fails
I have a RAK5146 gateway hat on a Pi 3 running Basic Station in a Docker container. I followed the instructions at 868 MHz RAK5146 SPI – LoRa Basics Station – LoRa@VSB – LoRaWAN Network of Technical University of Ostrava Campus | lora.vsb.cz. When I first connected my RAK5146 Pi3 gateway to TTN it worked fine, then I did a full delete and purge of the gateway to connect to TTN Arduino Cloud version and the gateway won’t make a persistent connection. It cycles continuously through connection attempts that end in failure. I generated a new EUI at Random EUI or Key generator | descartes and put that in the docker-compose.yml file, but I get the same cycling behavior.
Here is the log:
[+] Running 1/1
:heavy_check_mark: Container basicstation Created 0.0s
Attaching to basicstation
basicstation | ------------------------------------------------------------------
basicstation | BasicStation ™ Packet Forwarder Container v2.8.4
basicstation | (c) Xose Pérez 2022-2024
basicstation |
basicstation | Based on:
basicstation | * basicstation v2.0.6
basicstation | * sx1302_hal v2.1.0
basicstation | * picoGW_hal v0.2.3
basicstation |
basicstation | Protocol
basicstation | Mode: STATIC
basicstation | Protocol: LNS
basicstation | LNS Server: wss://arduino.nam1.cloud.thethings.industries:8887
basicstation | Gateway EUI: B827EBFFFEB31100
basicstation | EUI Source: file
basicstation |
basicstation | Radio
basicstation | Model: RAK5146
basicstation | Concentrator: SX1303
basicstation | Design: CORECELL
basicstation | Interface: SPI
basicstation | Radio Device: /dev/spidev0.1
basicstation | SPI Speed: 8000000
basicstation | Reset GPIO: 17
basicstation | Enable GPIO: 0
basicstation |
basicstation | Killing process group 1
basicstation | 2025-04-19 23:47:18.567 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)
basicstation | 2025-04-19 23:47:18.567 [SYS:INFO] Station Ver : 2.0.6(corecell/stdn) 2024-08-27 09:53:19
basicstation | 2025-04-19 23:47:18.567 [SYS:INFO] Package Ver : (null)
basicstation | 2025-04-19 23:47:18.568 [SYS:INFO] mbedTLS Ver : 2.28.0
basicstation | 2025-04-19 23:47:18.568 [SYS:INFO] proto EUI : b827:ebff:feb3:1100 (station.conf)
basicstation | 2025-04-19 23:47:18.568 [SYS:INFO] prefix EUI : ::1 (builtin)
basicstation | 2025-04-19 23:47:18.568 [SYS:INFO] Station EUI : b827:ebff:feb3:1100
basicstation | 2025-04-19 23:47:18.568 [SYS:INFO] Station home: ./ (builtin)
basicstation | 2025-04-19 23:47:18.568 [SYS:INFO] Station temp: /var/tmp/ (builtin)
basicstation | 2025-04-19 23:47:18.568 [SYS:INFO] GPS device: ./
basicstation | 2025-04-19 23:47:18.568 [SYS:WARN] Station in NO-CUPS mode
basicstation | 2025-04-19 23:47:18.570 [RAL:DEBU] execvp argv[0]: </proc/self/exe>
basicstation | 2025-04-19 23:47:18.570 [RAL:DEBU] argv[1]: <-S>
basicstation | 2025-04-19 23:47:18.571 [RAL:DEBU] argv[2]: <(null)>
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Logging : stderr (maxsize=10000000, rotate=3)
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Station Ver : 2.0.6(corecell/stdn) 2024-08-27 09:53:19
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Package Ver : (null)
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] mbedTLS Ver : 2.28.0
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] proto EUI : b827:ebff:feb3:1100 (station.conf)
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] prefix EUI : ::1 (builtin)
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Station EUI : b827:ebff:feb3:1100
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Station home: ./ (builtin)
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Station temp: /var/tmp/ (builtin)
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Station slave: 0
basicstation | 2025-04-19 23:47:18.575 [S00:WARN] Station in NO-CUPS mode
basicstation | 2025-04-19 23:47:18.575 [S00:INFO] Slave LGW (0) - started.
basicstation | 2025-04-19 23:47:18.570 [RAL:INFO] Master has started slave: pid=41 idx=0 (attempt 1)
basicstation | 2025-04-19 23:47:18.769 [GPS:ERRO] Failed to open TTY ‘./’: Is a directory
basicstation | 2025-04-19 23:47:18.769 [GPS:CRIT] Initial open of GPS FIFO ‘./’ failed - GPS disabled!
basicstation | 2025-04-19 23:47:18.770 [TCE:INFO] Starting TC engine
basicstation | 2025-04-19 23:47:18.930 [AIO:INFO] ./tc.trust:
basicstation | cert. version : 3
basicstation | serial number : 04:00:00:00:00:01:15:4B:5A:C3:94
basicstation | issuer name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
basicstation | subject name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
basicstation | issued on : 1998-09-01 12:00:00
basicstation | expires on : 2028-01-28 12:00:00
basicstation | signed using : RSA with SHA1
basicstation | RSA key size : 2048 bits
basicstation | basic constraints : CA=true
basicstation | key usage : Key Cert Sign, CRL Sign
basicstation | 2025-04-19 23:47:18.931 [TCE:INFO] Connecting to INFOS: wss://arduino.nam1.cloud.thethings.industries:8887
basicstation | 2025-04-19 23:47:20.190 [TCE:INFO] Infos: b827:ebff:feb3:1100 muxs-::0 wss://arduino.nam1.cloud.thethings.industries:8887/traffic/eui-B827EBFFFEB31100
basicstation | 2025-04-19 23:47:20.190 [AIO:DEBU] [4] ws_close reason=1000
basicstation | 2025-04-19 23:47:20.190 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
basicstation | 2025-04-19 23:47:20.190 [AIO:DEBU] [4] WS connection shutdown…
basicstation | 2025-04-19 23:47:20.344 [AIO:INFO] ./tc.trust:
basicstation | 2025-04-19 23:47:20.344 [TCE:VERB] Connecting to MUXS…
basicstation | 2025-04-19 23:47:21.376 [S00:VERB] /app/config/reset.sh: Forked, waiting…
basicstation | 2025-04-19 23:47:21.376 [S00:DEBU] execvp argv[0]: </app/config/reset.sh>
basicstation | 2025-04-19 23:47:21.376 [S00:DEBU] argv[1]: </dev/spidev0.1>
basicstation | 2025-04-19 23:47:21.377 [S00:DEBU] argv[2]: <0>
basicstation | Concentrator reset through GPIO17 (using sysfs)
basicstation | 2025-04-19 23:47:21.304 [TCE:VERB] Connected to MUXS.
basicstation | 2025-04-19 23:47:21.335 [RAL:INFO] Region plan hwspec ‘sx1301/1’ mapped to 1 slaves ‘sx1301/1’
basicstation | 2025-04-19 23:47:21.335 [RAL:INFO] Master sending 645 bytes of JSON sx1301conf to slave (0)
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] Configuring for region: US915 – 923.0MHz…928.0MHz
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR0 SF10/BW125
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR1 SF9/BW125
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR2 SF8/BW125
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR3 SF7/BW125
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR4 SF8/BW500
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR5 FSK
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR6 FSK
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR7 FSK
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR8 SF12/BW500
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR9 SF11/BW500
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR10 SF10/BW500
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR11 SF9/BW500
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR12 SF8/BW500
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR13 SF7/BW500
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR14 FSK
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] DR15 FSK
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] TX power: 26.0 dBm EIRP
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] JoinEui list: 0 entries
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] NetID filter: FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] Dev/test settings: nocca=1 nodc=1 nodwell=1
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] Beaconing every 2m8s on 923.3MHz(8) @ DR8 (frame layout 5/11/23)
basicstation | 2025-04-19 23:47:21.335 [S2E:INFO] Beaconing suspend - missing GPS data: time
basicstation | Warning: /sys/class/gpio/gpio17 does not exist
basicstation | 2025-04-19 23:47:21.408 [S00:INFO] Process /app/config/reset.sh (pid=42) completed
basicstation | 2025-04-19 23:47:21.408 [S00:INFO] Lora gateway library version: Version: 2.1.0;
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] [LGW sx1302] full_duplex=0 clksrc=0 lorawan_public=1
basicstation | 2025-04-19 23:47:21.409 [S00:DEBU] SX130x txlut table (16 entries)
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 0: rf_power=12 pa_gain=0 pwr_idx=15
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 1: rf_power=13 pa_gain=0 pwr_idx=16
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 2: rf_power=14 pa_gain=0 pwr_idx=17
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 3: rf_power=15 pa_gain=0 pwr_idx=19
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 4: rf_power=16 pa_gain=0 pwr_idx=20
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 5: rf_power=17 pa_gain=0 pwr_idx=22
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 6: rf_power=18 pa_gain=1 pwr_idx=1
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 7: rf_power=19 pa_gain=1 pwr_idx=2
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 8: rf_power=20 pa_gain=1 pwr_idx=3
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 9: rf_power=21 pa_gain=1 pwr_idx=4
basicstation | 2025-04-19 23:47:21.409 [S00:INFO] SX1302 txlut 10: rf_power=22 pa_gain=1 pwr_idx=5
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] SX1302 txlut 11: rf_power=23 pa_gain=1 pwr_idx=6
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] SX1302 txlut 12: rf_power=24 pa_gain=1 pwr_idx=7
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] SX1302 txlut 13: rf_power=25 pa_gain=1 pwr_idx=9
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] SX1302 txlut 14: rf_power=26 pa_gain=1 pwr_idx=11
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] SX1302 txlut 15: rf_power=27 pa_gain=1 pwr_idx=14
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] RX/TX RF0: 904.3MHz rssi_offset=-215.4 type=5 rssi_tcomp=0.000 0.000 20.410 2162.560 0.000
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] RX RF1: 905.0MHz rssi_offset=-215.4 type=5 rssi_tcomp=0.000 0.000 20.410 2162.560 0.000
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 0: 903.9MHz rf=0 freq=-400.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 1: 904.1MHz rf=0 freq=-200.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 2: 904.3MHz rf=0 freq= +0.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 3: 904.5MHz rf=0 freq=+200.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 4: 904.7MHz rf=1 freq=-300.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 5: 904.9MHz rf=1 freq=-100.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 6: 905.1MHz rf=1 freq=+100.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [mSF] 7: 905.3MHz rf=1 freq=+300.0 datarate=0
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [STD] 8: 904.6MHz rf=0 freq=+300.0 datarate=8 bw=6 Explicit header
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] channel 9 disabled
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] Station device: spi:/dev/spidev0.1 (PPS capture disabled)
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [lgw_com_open:84] Opening SPI communication interface
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [lgw_spi_open:88] Setting SPI speed to 8000000
basicstation | 2025-04-19 23:47:21.410 [S00:INFO] [lgw_connect:1192] chip version is 0x00 (v0.0)
basicstation | ERROR: Failed to set SX1250_0 in STANDBY_RC mode
basicstation | 2025-04-19 23:47:23.011 [S00:ERRO] [lgw_start:908] failed to setup radio 0
basicstation | 2025-04-19 23:47:23.011 [S00:ERRO] Concentrator start failed: lgw_start
basicstation | 2025-04-19 23:47:23.011 [S00:CRIT] Slave radio start up failed with status 0x08
basicstation | 2025-04-19 23:47:22.972 [RAL:ERRO] Slave (0) - EOF
basicstation | 2025-04-19 23:47:22.973 [any:CRIT] Slave pid=41 idx=0: Fatal exit
basicstation exited with code 0
Here is my docker-compose.yml
version: ‘2.0’
services:
basicstation:
image: xoseperez/basicstation:latest
container_name: basicstation
restart: unless-stopped
privileged: true
network_mode: host # Required to read main interface MAC instead of virtual one
environment:
MODEL: “RAK5146”
TC_KEY: "NNSXS.X2SYTWTGZ4HWICE55FIXLRW3JBQX2IHKEYRPY3A.K7UEK4RWA2ZP445KFCRDK6RDXVOMMAKGZHHO>
TTS_REGION: “us1”
GATEWAY_EUI: “B827EBFFFEB31100”
SERVER: “arduino.nam1.cloud.thethings.industries”
Can anyone help me figure out what is going wrong?
Hi Ben, if you are in Europe, you want to use eu1 not nam1 for the prefix of the things server. Also I just went through a hell of a time with my 5146 concentrator only to find out it was the usb version not the spi version though they both have the same form factor. You should see a green led if your concentrator is configured properly. I would go back to rakpios-cli and check all your variables to be sure you are using all the European settings. Also make sure the eui number returned is the same one you are using in the things network which should also be in Europe not North America.
Finally if that’s still not working chat gpt will help you configure the concentrator with generic raspberry pi lite os. It’s pretty insane it’s like having a tech right next to you.
