Feb 5 18:40:02 rak-gateway ttn-gateway[458]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: ### [GPS] ###
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # Invalid time reference (age: 1644086345 sec)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # no valid GPS coordinates available yet
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: ##### END #####
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“stat”:{“time”:“2022-02-05 18:39:05 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“temp”:34.8}}
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: INFO: [up] PUSH_ACK received in 1 ms
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: INFO: [down] PULL_ACK received in 0 ms
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: ##### 2022-02-05 18:39:35 GMT #####
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: ### [UPSTREAM] ###
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # RF packets received by concentrator: 0
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # RF packets forwarded: 0 (0 bytes)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # PUSH_DATA datagrams sent: 1 (125 bytes)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # PUSH_DATA acknowledged: 100.00%
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: ### [DOWNSTREAM] ###
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # PULL_DATA sent: 3 (100.00% acknowledged)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # RF packets sent to concentrator: 0 (0 bytes)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # TX errors: 0
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # TX rejected (collision packet): 50.00% (req:4, rej:2)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # TX rejected (collision beacon): 0.00% (req:4, rej:0)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # TX rejected (too late): 0.00% (req:4, rej:0)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # TX rejected (too early): 0.00% (req:4, rej:0)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: ### SX1302 Status ###
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # SX1302 counter (INST): 450874372
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # SX1302 counter (PPS): 316419876
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # BEACON queued: 0
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # BEACON sent so far: 0
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # BEACON rejected: 0
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: ### [JIT] ###
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: #--------
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: # Invalid time reference (age: 1644086375 sec)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“stat”:{“time”:“2022-02-05 18:39:35 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“temp”:34.4}}
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: INFO: Received pkt from mote: 4C570001 (fcnt=16707)
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:452255135,“chan”:1,“rfch”:1,“freq”:868.300000,“mid”: 0,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-56,“lsnr”:8.5,“foff”:-1356,“rssi”:-56,“size”:23,“data”:“AAEAV0xNQ0FIQBEAAiFpM4PrsyltvIM=”},{“jver”:1,“tmst”:452255135,“chan”:4,“rfch”:0,“freq”:867.300000,“mid”: 3,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-129,“lsnr”:-14.2,“foff”:-1357,“rssi”:-116,“size”:23,“data”:“AAEAV0xNQ0FIQBEAAiFpM4PrsyltvIM=”}]}
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: INFO: [up] PUSH_ACK received in 2 ms
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:460337135,“chan”:0,“rfch”:1,“freq”:868.100000,“mid”: 0,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-56,“lsnr”:7.8,“foff”:-1339,“rssi”:-56,“size”:23,“data”:“AAEAV0xNQ0FIQBEAAiFpM4MsABjdueM=”}]}
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: INFO: [up] PUSH_ACK received in 0 ms
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:462071148,“chan”:2,“rfch”:1,“freq”:868.500000,“mid”: 0,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-61,“lsnr”:6.2,“foff”:-3294,“rssi”:-60,“size”:23,“data”:“AAEAV0xNQ0FIhSQAAiFpM4PdSKc2h1E=”}]}
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:468418772,“chan”:1,“rfch”:1,“freq”:868.300000,“mid”: 0,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-56,“lsnr”:7.5,“foff”:-1351,“rssi”:-55,“size”:23,“data”:“AAEAV0xNQ0FIQBEAAiFpM4Nfs07opmA=”}]}
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:470154251,“chan”:2,“rfch”:1,“freq”:868.500000,“mid”: 0,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-60,“lsnr”:6.8,“foff”:-3258,“rssi”:-59,“size”:23,“data”:“AAEAV0xNQ0FIhSQAAiFpM4Me3Abeil8=”}]}
Feb 5 18:40:02 rak-gateway chirpstack-gateway-bridge[590]: time=“2022-02-05T18:40:02.598130031Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=gateway/e45f01fffe7c7251/event/up uplink_id=5b6968fb-438d-4ae7-8074-c2232e3a12c9
Feb 5 18:40:02 rak-gateway ttn-gateway[458]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:473655532,“chan”:0,“rfch”:1,“freq”:868.100000,“mid”: 0,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-66,“lsnr”:8.2,“foff”:-3296,“rssi”:-65,“size”:23,“data”:“AAEAV0xNQ0FIYCUAAiFpM4Omu1LVvtg=”}]}
Feb 5 18:40:05 rak-gateway chirpstack-gateway-bridge[590]: time=“2022-02-05T18:40:05.221060322Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=eb43d2c6-2ed5-4c46-ad8e-1746a9814a69 topic=gateway/e45f01fffe7c7251/event/stats
Feb 5 18:40:06 rak-gateway chirpstack-gateway-bridge[590]: time=“2022-02-05T18:40:06.104259258Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=gateway/e45f01fffe7c7251/event/up uplink_id=d88a9610-11ab-45c5-90a6-1b9d494bda9b
Feb 5 18:40:14 rak-gateway chirpstack-gateway-bridge[590]: time=“2022-02-05T18:40:14.175970065Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=gateway/e45f01fffe7c7251/event/up uplink_id=13a0e3a4-536f-4977-9fff-2e271e633c28
Feb 5 18:40:35 rak-gateway chirpstack-gateway-bridge[590]: time=“2022-02-05T18:40:35.222948774Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=c9f52656-a9c5-40b8-b221-4e10c84b83c9 topic=gateway/e45f01fffe7c7251/event/stats
Feb 5 18:40:45 rak-gateway chirpstack-gateway-bridge[590]: time=“2022-02-05T18:40:45.011682493Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=gateway/e45f01fffe7c7251/event/up uplink_id=05ab8f30-e3f5-490a-9888-bc12b08619fe
