Hello RAK Forum,
I am experiencing an issue with my Semtech RAK5148, 2.4 G device on my Raspberry Pi. The device intermittently disconnects and reconnects, causing disruptions. Here are the relevant log entries from dmesg:
Jul 11 18:39:14 rakpios kernel: usb 3-1.3: USB disconnect, device number 3
Jul 11 18:39:14 rakpios kernel: usb 3-1.3: new full-speed USB device number 7 using dwc2
Jul 11 18:39:14 rakpios kernel: usb 3-1.3: New USB device found, idVendor=05c9, idProduct=5740, bcdDevice= 2.00
Jul 11 18:39:14 rakpios kernel: usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 11 18:39:14 rakpios kernel: usb 3-1.3: Product: GTW 2G4 VPC
Jul 11 18:39:14 rakpios kernel: usb 3-1.3: Manufacturer: Semtech
Jul 11 18:39:14 rakpios kernel: usb 3-1.3: SerialNumber: 205332843831
after the disconnect happened, this is the output of dmesg | grep tty
rak@rakpios:~ $ dmesg | grep tty
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=D8:3A:DD:05:A5:13 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=3b45ec03-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000411] printk: console [tty1] enabled
[ 1.443060] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[ 2.777551] systemd[1]: Created slice system-getty.slice.
[ 8.497819] cdc_acm 3-1.3:1.0: ttyACM0: USB ACM device
[ 8.593959] usb 3-1.4.3: ch341-uart converter now attached to ttyUSB0
[ 8.598489] usb 3-1.4.4: ch341-uart converter now attached to ttyUSB1
[ 15.396069] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 15.397579] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB3
[ 15.402860] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB4
[ 15.403386] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB5
[25988.976428] cdc_acm 3-1.3:1.0: ttyACM1: USB ACM device
Steps I’ve Taken So Far:
Checked Physical Connections. This should not be an issue since the system is working for a few hours before the disconnection happened
Disabled USB autosuspend:
- Temporarily disabled USB autosuspend by executing:
echo -1 | sudo tee /sys/module/usbcore/parameters/autosuspend - Made the change persistent by adding
usbcore.autosuspend=-1to/boot/cmdline.txt:
console=serial0,115200 console=tty1 root=PARTUUID=3b45ec03-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles usbcore.autosuspend=-1
- Rebooted the system.
- Checked Device Logs:**
- Monitored
dmesglogs to verify the device behavior post changes.
- Monitored
Despite these steps, the issue persists. The device continues to disconnect and reconnect sporadically.
System Information:
- Raspberry Pi Model: CM4
- Operating System:RAKPIOS
- Device Model: RAK5148 Semtech-based concentrator
I am seeking help to resolve this issue. I would greatly appreciate any guidance on further troubleshooting steps or configuration adjustments. Has anyone else encountered similar issues with this or similar devices?
Thank you in advance for your assistance!
Best regards,
Iman
