I’m using the RAK5205 as a counter (see my previous topic Use interrupts in RAK5205)
For time to time without any event (the interrupt circuit is open) the counter increased.
it is connected to the header connector via a 3 pin 90 degree header (where jus 2 of the pins are connected) the wire to the sensor is 35cm long (https://www.monoprice.com/product?p_id=2824) 16awg.
I dont think the wire is the issue, it is much thicker than needed
I was interested if in it was picking up any interference - as @mamanbudiman suggests, a pull-up resistor (10k) would be appropriate as long as the wire is not routed next to a great big power transformer, lift motor or van de Graff generator.
Thanks @nmcc.
I’m trying to filter short noises so I detect RUI_GPIO_EDGE_FALL and increase my counter only after 300ms from the interrupt. I want to filter also short pulses width so I have to catch both edge fall and raise. Is it possible to detect both and differentiate between them?
Sure, use a volatile global to hold the state of the GPIO so when the edge interrupt is triggered, you can compare what was with what is and with another variable, you can track the time of the previous interrupt.
Or set up two interrupts one for fall and one for raise with similar variables.
