Oh boy. We did not expect this. Honestly we have no experience with anything other than TTN or LoRaServer as those are the only solutions that we know of that are worldwide and free.
There has to be something with the join procedure that is different in France than what we are familiar with.
I would expect that you have no problems with an ABP setup, right?
This is so strange, the join request response timing windows should be standardized and there should be no issues.
Perhaps you can provide us with a bit more information about the Objenious network, maybe we get an idea of what might be going wrong.
I assume there are no such issues with other nodes you have used?
Yes, however the windows length in time is different, so it is not exactly the standard RX2.
It is a bit different and I think it might be the issue. Not sure thought, we are not giving up we will think of something to try to find the problem, might take time though
I was mistaken with this trouble, finally all the last firmware versions (2.0.0.6, 2.0.1.8, 2.0.1.9) work when it is compiled with Keil!
But I usually compile it with Ac6 Open STM32 and the code generated don’t behave the same way.
What happens is that the MCU reboots during initialization and after.
Also, there are all this weird characters appearing after “BME680 init success!” and I tried to disable some external sensors (GPS, LIS3DH, BME680) in “BoardInitPeriph()”, but the only combination that worrks (join success and uplinks) was :
Yes, it works, but I need to make some changes in the payload format (LPP doesn’t seem to accept uint32 format) and I need to add some functionalities that doesn’t exist in precompiled firmware (hour engine counter from GPIO).
Also, I don’t have Keil compiler that is too much expensive for just one project, so I try to use AC6 STM32 free tools.
The compilation works with old firmware (1.1.3) but not since 2.x.x.x, so I try to add my functionalities in this old version without the benefit of new firmware:).
Hopping someone could help to find what is going wrong …
