I need to know which AT-command set I can use in order to change/make the Cellular_Ping example script configuration usable for KPN provider. (LTE-M)
I already changed the setting for KPN to:
AT+CGDCONT=1,“IP”,“kpnthings.iot”
BR,
Jeroen
BR,
Jeroen
Please be patient.
In my country is no CAT-M or NB-IoT available, so I cannot test anything. But I will loop in one of my team members.
If you need help for testing purposes, please let me know.
Hello @JeroenKl,
To help solve the problem could you please share the output of the serial console? After sending the command AT+QNWINFO
I’m testing with this code in order to get a LTE-M connection:
// should result in +CPIN: READY, if not sim pin is required
bg77_at(“AT+CPIN?”, 500);
delay(2000);
// frequency band
bg77_at(“AT+QCFG="band",1,80000,80000,1”, 500);
delay(2000);
// mode of operation
bg77_at(“AT+QCFG="iotopmode",0,1”, 500);
delay(2000);
// networkscan sequence
bg77_at(“AT+QCFG="nwscanseq",020202,1”, 500);
delay(2000);
// netwerk scan mode
bg77_at(“AT+QCFG="nwscanmode",3,1”, 500);
delay(2000);
// Roaming service (NOT WORKING)
//bg77_at(“AT+QCFG="roamservice",2,1”, 500);
//delay(2000);// KPN (Dutch provider) LTE-M APN
bg77_at(“AT+CGDCONT=1,"IP","kpnthings.iot"”, 500);
delay(2000);
// operator selection (auto)
bg77_at(“AT+COPS=0,2”, 500);
delay(2000);
// restart modem
bg77_at(“AT+CFUN=1,1”, 500);
delay(2000);// registration status: +CREG: 0,1 means registered
bg77_at(“AT+CREG?”, 500);
delay(2000);
// connected? +CGATT: 1 means connected
bg77_at(“AT+CGATT?”, 500);
delay(2000);
// bg77_at(“AT+CGATT=1”, 500);
// delay(2000);
// IP address (NOT WORKING)
bg77_at(“AT+CGPADDR?”, 500);
delay(2000);bg77_at(“AT+QNWINFO”, 500);
delay(2000);
bg77_at(“AT+QCSQ”, 500);
delay(2000);
// Signal level like: +CSQ: 24,99 (not: 99,99)
bg77_at(“AT+CSQ”, 500);
delay(2000);
bg77_at(“AT+QIACT=1”, 500);
delay(2000);
Serial Output (NOT STABLE):
18:28:44.206 → RAK4630 Cellular TEST With KPN NL LTE-M sim card!
18:28:48.196 → BG77 power up!
18:28:48.715 →
18:28:48.715 → RDY
18:28:48.715 → ATI18:28:48.715 → Quectel
18:28:48.715 → BG77
18:28:48.715 → Revision: BG77LAR02A02
18:28:48.715 →
18:28:48.715 → OK
18:28:48.715 →
18:28:51.208 →
18:28:53.696 →
18:28:53.696 → RDY
18:28:53.696 →
18:28:56.185 →
18:28:56.185 → RDY
18:28:56.185 → AT+QCFG=“iotopmode”,0,118:28:56.185 → OK
18:28:56.185 →
18:28:58.680 →
18:28:58.680 → RDY
18:28:58.680 →
18:29:01.173 →
18:29:03.669 →
18:29:03.669 → RDY
18:29:03.669 →
18:29:06.160 →
18:29:06.160 → RDY
18:29:06.160 → AT+CGDCONT=1,“IP”,“kpnthings.iot”18:29:06.160 → OK
18:29:06.160 →
18:29:08.699 →
18:29:11.192 →
18:29:11.192 → RDY
18:29:11.192 →
18:29:13.670 →
18:29:13.670 → RDY
18:29:13.670 → AT+CREG?18:29:13.670 → +CREG: 0,2
18:29:13.670 →
18:29:13.670 → OK
18:29:13.670 →
18:29:16.181 →
18:29:16.181 → APP RDY
18:29:16.181 →
18:29:18.665 →
18:29:18.665 → RDY
18:29:18.665 → AT+CGATT=118:29:21.182 →
18:29:21.182 → OK
18:29:21.182 → AT+CGPADDR?18:29:21.182 → ERROR
18:29:21.182 →
18:29:23.675 → AT+QNWINFO18:29:23.675 → +QNWINFO: “eMTC”,“20408”,“LTE BAND 20”,6400
18:29:23.675 →
18:29:23.675 → OK18:29:26.168 → AT+QCSQ
18:29:26.168 → +QCSQ: “eMTC”,-80,-109,118,-13
18:29:26.168 →
18:29:26.168 → OK
18:29:26.168 →
18:29:28.666 → AT+CSQ18:29:28.666 → +CSQ: 17,99
18:29:28.666 →
18:29:28.666 → OK
18:29:28.666 →
18:29:33.618 → AT+QIACT=118:29:33.618 → OK
18:29:33.618 →
18:29:35.586 → Begin receive packet from www.kpn.nl!
18:29:45.375 → AT+QPING=1,”1.1.1.1”,4,418:29:45.375 → ERROR
any advice?
BR,
Jeroen
Hello @JeroenKl,
I can’t found the at command AT+QICSGP to configure APN
“apn_name”, username, password
Set the APN to “hologram” with no username or password.
AT+QICSGP=1,1,"hologram","","",1
Then Activate the PDP context.
AT+QIACT=1
If ok you then you can establish the TCP connection and send AT+QPING
Hi @marcio,
It looks like ‘Hologram’ isn’t the correct way in order to set the APN for KPN provider in the Netherlands. I made progress with:
AT+CGDCONT=1,“IP”,“kpnthings.iot” and AT+CGACT=1,1
Now I’m getting an IP address but still not able to ping the WAN network:
21:42:46.685 → AT+CGATT=1
21:42:46.685 → OK21:42:51.196 → AT+CGDCONT=1,“IP”,“kpnthings.iot”
21:42:51.196 → OK21:42:55.716 → AT+CGACT=1,1
21:42:55.716 → OK21:43:00.194 → AT+CGPADDR=1
21:43:00.194 → +CGPADDR: 1,10.11.1.231
21:43:00.194 → OK21:43:04.706 → AT+QNWINFO
21:43:04.706 → +QNWINFO: “eMTC”,“20408”,“LTE BAND 20”,6400
21:43:04.706 → OK21:43:09.180 → AT+QCSQ
21:43:09.180 → +QCSQ: “eMTC”,-83,-111,117,-12
21:43:09.180 → OK21:43:13.694 → AT+CSQ
21:43:13.694 → +CSQ: 15,99
21:43:13.694 → OK21:43:18.205 → AT+QIACT=1
21:43:18.205 → OK21:43:22.202 → Begin receive packet from www.kpn.nl!
21:43:31.945 → AT+QPING=1,”8.8.8.8”21:43:31.945 → ERROR
21:43:31.945 →
21:43:32.976 → Begin receive packet from www.kpn.nl!
Why can I not ping to WAN (yet)?
BR,
Jeroen
Hi @JeroenKl,
Can you try “internet” as the APN? Where did you find “kpnthings.iot” as the APN for KPN?
This APN is provided by KPN together with 2 test LTE-M sims I received.
I see. It seems if you will use their standard cellular connection (2G, 3G, LTE), you can use “internet” but you got an IoT sim for LTE-M that’s why you need to use kpnthings.iot. That’s how I understand it, I might be wrong.
Also, on your screenshot, you have multiple RDY replies from module. That can be an indicator that the module doesn’t not have a good power source.
Hello @JeroenKl,
Hologram is global sim card.
(Hologram
KPNThings has another APN.
Have you tested kpn sim card on cell phone?
For hologram sim card you need to activate it before using.
I do not have Hologram SIM, but I have KPN LTE-M Sims with KPN APN which I need to use according KPN.
It is activated, I get a connection and IP address but cannot ping (error message)
You are right, this is the case
I’m using the Cellular_ping INO which requires a terminal connection. So the device is hooked up to my laptop.
I can change the setting so the device will run without a serial connection but then I cannot see if the ping is working.
I think it is time to provide a ‘example, solution’ script (INO)
Hi @carlrowan,
Could you please check if the LTE-M (CAT-M1) functionality is tested thoroughly and confirmed it should work according specs?
BR,
Jeroen
Hi @JeroenKl,
Marcio already tested it on his hologram sim and it works. Quectel forum is a good reference as well if a user from Netherlands successfully used KPN LTE-M1 connection using BG77.
Hi @carlrowan,
Thanks, of course I will not rest to have the KPN fixed so I’ll investigate further and keep you updated.
Any topic on Quectel forum you can pinpoint me regarding KPN LTE-M1?
Br,
Jeroen
@JeroenKl
The error message does not help much. You can add AT+CMEE=2 command to get more error details.
I also used the command AT+CFUN=1,0 before activate the PDP context.
