I am using a RAK5860 in conjunction with a RAK4630 using a RAK5005 baseboard.
I am trying to connect to the Hologram network using a sim card they provided.
Running the example code from the RAK Arduino sketch “Hologram_Ping_LTE” results in the following output, getting stuck at the “waiting for registration” step:
23:42:31.720 -> BG77 LTE ping test!
23:42:31.720 -> Modem response after start:
23:42:31.720 -> ATI
23:42:31.720 -> Quectel
23:42:31.720 -> Revision: BG77LAR02A04
23:42:31.720 ->
23:42:31.720 -> OK
23:42:31.720 ->
23:42:35.730 -> BG77 power up!
23:42:37.177 -> AT+CMEE=2
23:42:37.177 -> OK
23:42:37.177 ->
23:42:38.580 -> AT+CFUN=1,0
23:42:38.580 -> OK
23:42:38.580 ->
23:42:40.513 -> AT+QCFG="iotopmode",0,1
23:42:40.513 -> OK
23:42:40.513 ->
23:42:42.512 -> AT+QICSGP=1,1,"hologram","","",1
23:42:42.512 -> OK
23:42:42.512 ->
23:42:42.512 -> Waiting for registration
Here is the code used, found at [WisBlock/Hologram_Ping_LTE.ino at master · RAKWireless/WisBlock · GitHub] (WisBlock/Hologram_Ping_LTE.ino at master · RAKWireless/WisBlock · GitHub)
* @file BG77_Hologram_Ping.ino
* @author rakwireless.com
* @brief RAK4631 + RAK5860 BG77 module product testing
* @version 0.1
* @date 2021-01-26
* @copyright Copyright (c) 2021
* @note RAK5005-O GPIO mapping to RAK4631 GPIO ports
RAK5005-O <-> nRF52840
IO1 <-> P0.17 (Arduino GPIO number 17)
IO2 <-> P1.02 (Arduino GPIO number 34)
IO3 <-> P0.21 (Arduino GPIO number 21)
IO4 <-> P0.04 (Arduino GPIO number 4)
IO5 <-> P0.09 (Arduino GPIO number 9)
IO6 <-> P0.10 (Arduino GPIO number 10)
SW1 <-> P0.01 (Arduino GPIO number 1)
A0 <-> P0.04/AIN2 (Arduino Analog A2
A1 <-> P0.31/AIN7 (Arduino Analog A7
SPI_CS <-> P0.26 (Arduino GPIO number 26)
#include <Adafruit_TinyUSB.h>
#define BG77_POWER_KEY 17
char cArr[128] = {0};
String bg_rsp = "";
bool bg_timeout = false;
//this function is suitable for most AT commands of bg96. e.g. bg96_at("ATI")
boolean bg_at(char *at, uint16_t timeout)
bg_rsp = "";
char tmp[256] = {0};
int len = strlen(at);
strncpy(tmp, at, len);
uint16_t t = timeout;
tmp[len] = '\r';
Serial1.write(tmp);
delay(10);
while (t--)
if (Serial1.available())
bg_rsp += char(Serial1.read());
delay(1);
if( bg_rsp.length() > 0 )
bg_timeout = false;
else
bg_timeout = true;
return bg_timeout;
void deact(void)
// deactivate PDP
bg_at("AT+QIDEACT=1" ,1500);
// Set minimal UE Functionality
bg_at("AT+CFUN=0,0" ,1500);
void setup()
bool reg= false;
bool pdp_active = false;
// Open serial communications and wait for port to open:
while (!Serial)
delay(10);
Serial.println("BG77 LTE ping test!");
// Check if the modem is already awake
time_t timeout = millis();
bool moduleSleeps = true;
Serial1.begin(115200);
delay(1000);
Serial1.println("ATI");
//BG77 init
while ((millis() - timeout) < 6000)
String result = Serial1.readString();
Serial.println("Modem response after start:");
Serial.println(result);
moduleSleeps = false;
if (moduleSleeps)
// Module slept, wake it up
pinMode(BG77_POWER_KEY, OUTPUT);
digitalWrite(BG77_POWER_KEY, 0);
delay(1000);
digitalWrite(BG77_POWER_KEY, 1);
delay(2000);
delay(1000);
Serial.println("BG77 power up!");
// Verbose Error Reporting to get understandable error reporting
bg_timeout = bg_at("AT+CMEE=2" ,1500);
if ( bg_timeout == false )
if ( bg_rsp.indexOf('OK') > 0 )
Serial.println(bg_rsp);
else
return;
// Set full UE Functionality
bg_timeout = bg_at("AT+CFUN=1,0" ,1400);
if (bg_timeout == false)
else
return;
// Set eMTC LTE mode
bg_timeout = bg_at("AT+QCFG=\"iotopmode\",0,1",2000);
else
return;
// Set the APN to "hologram" with no username or password.
// Configure parameters of a TCP/IP context
bg_timeout = bg_at("AT+QICSGP=1,1,\"hologram\",\"\",\"\",1" ,2000);
if (bg_timeout == false )
else
return;
Serial.println("Waiting for registration");
do
reg=false;
bg_timeout = bg_at("AT+CREG?",2000);
int v = bg_rsp.indexOf('0,');
if ( v > 0 )
if ( bg_rsp[v+1] == '5' )
reg = true;
Serial.println("Registered: Roaming");
else if ( bg_rsp[v+1] == '1' )
reg = true;
Serial.println("Registered: Home");
delay(200);
} while (!reg);
// Get NW INFO
Serial.println("Waiting for NW Info");
do {
reg=false;
bg_timeout = bg_at("AT+QNWINFO",1000);
int v = bg_rsp.indexOf('eMTC');
if ( v >0 )
reg = true;
else
v = bg_rsp.indexOf('ervice');
if ( v >0 )
Serial.println("No service");
delay(200);
} while (!reg);
// Check if PDP IPV4 is activated
// Don't send data if PDP is deactivated
pdp_active = false;
bg_timeout = bg_at("AT+QIACT?",1500);
if ( bg_rsp.indexOf(',1,1') > 0 )
pdp_active = true;
Serial.println("PDP is activated");
else
return;
// Don't send PDP activate command if PDP is already activated
if ( pdp_active == false )
Serial.println("Activating PDP");
do {
reg=false;
bg_timeout = bg_at("AT+QIACT=1",1500);
if ( bg_rsp.indexOf('OK') >0 )
reg = true;
delay(200);
} while (!reg);
void loop()
int timeout = 100;
int retry = 3;
String resp = "";
String snd = "";
int v;
// char cArr[128] = {0};
if (bg_timeout == true)
Serial.print("Timeout during initialization");
while(1);
delay(100);
while ( retry--)
Serial.println("Sending ping");
bg_at( "AT+QPING=1,\"baidu.com\",15,1",5000 );
v = bg_rsp.indexOf('RROR');
if ( v > 0)
Serial.println( "Ping error...retry" );
continue;
// Result => 0 received the ping response from the server
v = bg_rsp.indexOf('+QPING: 0,"');
if ( v >0 )
v = bg_rsp.indexOf('+QPING: 0,1,1');
if ( v >0 )
Serial.println( "1 ping sent 1 ping received" );
break;
delay(200);
} // retry--
Serial.println("Waiting AT command");
while (1)
timeout = 100;
while (timeout--)
if (Serial1.available() > 0)
resp += char(Serial1.read());
if (Serial.available() > 0)
snd += char(Serial.read());
delay(1);
if (resp.length() > 0)
Serial.print(resp);
if (snd.length() > 0)
memset(cArr, 0, 128);
snd.toCharArray(cArr, snd.length() + 1);
Serial1.write(cArr);
delay(10);
resp = "";
snd = "";
