I am running the sample code “Hologram_TCP”. I have filled in my correct Device Key. The device is connected to cellular (according to hologram), but I dont see any data coming through in the Hologram logs.
Here is the output from the Arduino Console:
AT+CPIN?
+CPIN: READY
OK
APP RDY
AT+QNWINFO
+QNWINFO: "eMTC","310260","LTE BAND 12",5035
OK
AT+QCSQ
+QCSQ: "eMTC",-86,-111,136,-12
OK
+CSQ: 15,99
OK
OK
OK
Send test data to Hologram via TCP!
OK
+QIOPEN: 0,565
+QGPSLOC: 200501.000,2957.7815N,9813.4475W,3.6,352.3,3,0.00,0.0,0.0,
OK
{"k":"eOhYKlms","d":2957.7815N,9813.4475W,"t":"TOPIC1"}
OK
+QGPSLOC: 201038.000,2957.7871N,9813.4546W,1.6,346.8,3,0.00,0.0,0.0
OK
{"k":"eOhYKlms","d":2957.7871N,9813.4546W,"t":"TOPIC1"}
When I check the log in Hologram to see if the device successful transmitted data, I don’t see anything. The last message I see was from a month ago when I did a SIM swap. See below:
Here is the code I am currently running:
@file Hologram_Tcp.ino
@author rakwireless.com
@brief BG77 tcp test with Hologram, send gps data to server
@version 0.1
@date 2020-12-28
@copyright Copyright (c) 2020
#include <Adafruit_TinyUSB.h>
#define BG77_POWER_KEY WB_IO1
#define BG77_GPS_ENABLE WB_IO2
String bg77_rsp = "";
//Hologarm tcp message format is jason. Remember to replace the card key in type k.
//About key details: https://support.hologram.io/hc/en-us/articles/360035212714-Device-keys
//About message details: https://www.hologram.io/references/embedded-apis#send-a-message-to-the-hologram-cloud
String hologram_msg_pre = "{\"k\":\"eOhYKlms\",\"d\":";
String hologram_msg_suff = ",\"t\":\"TOPIC1\"}";
String hologram_msg = "";
String send_data_length_at = "";
String gps_data = "";
void setup()
while (!Serial)
if ((millis() - serial_timeout) < 5000)
delay(100);
else
break;
Serial.println("RAK11200 Cellular TEST With Hologram sim card!");
//BG77 init , Check if the modem is already awake
time_t timeout = millis();
bool moduleSleeps = true;
Serial1.begin(115200);
delay(1000);
pinMode(BG77_GPS_ENABLE, OUTPUT);
digitalWrite(BG77_GPS_ENABLE, 1);
Serial1.println("ATI");
//BG77 init
while ((millis() - timeout) < 6000)
if (Serial1.available())
String result = Serial1.readString();
Serial.println("Modem response after start:");
Serial.println(result);
moduleSleeps = false;
if (moduleSleeps)
// Module slept, wake it up
pinMode(BG77_POWER_KEY, OUTPUT);
digitalWrite(BG77_POWER_KEY, 0);
delay(1000);
digitalWrite(BG77_POWER_KEY, 1);
delay(2000);
delay(1000);
Serial.println("BG77 power up!");
//active and join to the net, this part may depend on some information of your operator.
bg77_at("AT+CFUN=1,0", 500);
delay(2000);
bg77_at("AT+CPIN?", 500);
delay(2000);
bg77_at("AT+QNWINFO", 500);
delay(2000);
bg77_at("AT+QCSQ", 500);
delay(2000);
bg77_at("AT+CSQ", 500);
delay(2000);
bg77_at("AT+QIACT=1", 3000);
delay(2000);
//open tcp link with Hologram server
bg77_at("AT+QIOPEN=1,0,\"TCP\",\"cloudsocket.hologram.io\",9999,0,1", 5000);
delay(2000);
void parse_gps()
int index1 = gps_data.indexOf(',');
if(strstr(gps_data.c_str(),"E") != NULL)
int index2 = gps_data.indexOf('E');
gps_data = gps_data.substring(index1+1,index2+1);
if(strstr(gps_data.c_str(),"W") != NULL)
int index3 = gps_data.indexOf('W');
gps_data = gps_data.substring(index1+1,index3+1);
void get_gps()
int gps_count = 300;
int timeout = 1000;
while(gps_count--)
Serial1.write("AT+QGPSLOC?\r");
timeout = 1000;
while (timeout--)
gps_data += char(Serial1.read());
delay(1);
if(strstr(gps_data.c_str(),"CME ERROR") != NULL)
gps_data = "";
continue;
if(strstr(gps_data.c_str(),"E") != NULL || strstr(gps_data.c_str(),"W") != NULL)
Serial.println(gps_data);
parse_gps();
break;
//this function is suitable for most AT commands of bg96. e.g. bg96_at("ATI")
void bg77_at(char *at, uint16_t timeout)
char tmp[256] = {0};
int len = strlen(at);
strncpy(tmp, at, len);
uint16_t t = timeout;
tmp[len] = '\r';
Serial1.write(tmp);
delay(10);
while (t--)
bg77_rsp += char(Serial1.read());
delay(1);
Serial.println(bg77_rsp);
bg77_rsp = "";
void send_test_data()
//open gps, gsm/nb will stop work now
bg77_at("AT+QGPS=1,1", 20000);
//get gps data, this will cost some time
get_gps();
//close gps
bg77_at("AT+QGPSEND", 2000);
//combine the data packet
hologram_msg = hologram_msg_pre+gps_data+hologram_msg_suff;
Serial.println(hologram_msg);
gps_data = "";
//send data length command
send_data_length_at = "AT+QISEND=0," + hologram_msg.length();
strncpy(tmp, send_data_length_at.c_str(), send_data_length_at.length());
bg77_at(tmp, 3000);
delay(2000);
//send data
memset(tmp,0,256);
strncpy(tmp, hologram_msg.c_str(), hologram_msg.length());
bg77_at(tmp, 1000);
delay(1000);
void loop()
Serial.println("Send test data to Hologram via TCP!");
send_test_data();
//consider the gps fix time, interval should be long
delay(300000);
Any thoughts on how to get data to post on Hologram?
