I have a RAK6243 board which has RAK2245 Pi Hat and Raspberry pi. Its 915 MHz. I am not able to find the appropriate firmware for it. In the firmware folder I can see three images. I tried all three of them. With one image (RAK2245_based_on_Raspbian_OS_for_RPI3_V4.1.0_20191202) the board doesn’t bootup at all and with two others (RAK2245_based_on_Raspbian_V4.1.0_20191129 and RAK2245_based_on_Raspbian_OS_V2.9.2_20190820) the bootup hangs after
[ 0.688457] mmc1: new high speed SDIO card at address 0001
[ 279.874076] random : crng init done
Can you please help me as I am stuck at this point since sometime.
Were you able to get it to work? I am having the exact same problem. None of the firmwares listed work. Reading the steps on the github I get lost as I normally don’t use the pi hardware. Had to order a new Pi b+ for this project. It just hangs and reboots.
I don’t know how but I got it to install and was able to use putty to set it up. I followed the instructions but It never shows connection and when I plug the pi into a monitor it hangs at rak-gateway login: and shows not connected on the TTN site, also never seen.
Edit: I am using a RPI 3 B+ and RAK2245&RAK831_based_on_Raspbian_OS_for_RPI3_V4.1.0_20191202 firmware.
Connected via wifi to my home network. I can see it on the network and use putty connecting to the gateway on my home network as well.
