RAK7200 node, GPS tracker
Same for me.
Also updated the bootloader.
Unfortunately the battery read-out is gone in de serial logger.
Does anyone know where a payload-decode can be found?
I’t doesn’t make any sense that everyone has to invent the wheel to get access to our data :frowning:
Hi @Henning,
https://doc.rakwireless.com/rak7200-lora-tracker/analyzing-the-data-from-rak7200
Yep. I’ve seen that page and others like it, but I wunder why you ( or someone else ) haven’t published e decoder-function for copy-pasting to the ttn-console.
Well. I’d better publish my own, when I (re) invert it.
/Henning
Agree. I have tried to decode RAK7204 my self with documentation but code looks bulky and unclear and i’m not confident to post it for other to use.
And contain multible errors :frowning:
Wrong values, wrong labels.
Better look closely and try to validate data from ā€œtrustedā€ sources before using it in real.
I have a similar problem, I posted but nobody answer.
I have a RAK7249. When the RAK7200 tracker send Payload, they are total different that they must be as RAK packet decode say.
I get:
02 C0 04 29 BD F5 CF B9 DB 7A 2F 9B 70 5D 6E 89 E6 4E A9 51 DC DA EB F4 47 A1 64 7C F7 D5 70 55 27 7B 17 76 30 6A 68
instead of:
018805378F109D590103CE080201750371FF000000FE000586FFFD0000000104020143FF
6C005F0673253202670139
(Both of this are only examples one from my data, other from PDF of RAK, they don’t match in length)
Then I tried to send a little data from the RAK SERIAL PROTOCOL TOOL
I sent several times:
at+send=lora:1:018805378F109D59
and get different payloads:
01 53 4B 34 66 D7 1F E7
01 AF 4F 89 E4 24 55 9A
01 E6 17 F3 00 4C 02 52
Then I sent in other port:
at+send=lora:2:018805378F109D59
and get:
02 70 99 7A C1 08 CD 22
02 3E 76 FD AD 43 EF B7
Any explanation of this?
Is this correct? As still the temp and pressure sensor is mentioned but it is not available in the 7200?
Where did you see the data in RAK7249?
In the inbuild lora server
The data you receive is base64 data, not hex, you can switch this piece to hex, and then try again.
I have issue regarding GPS accuracy.
My device is updated with latest firmware still I am not getting accurate GPS location.
Please reply if anyone facing similar issues
Sorry for late.
The new document has been updated here:
Hi @Aks666,
Sorry for late reply.
Can you please turn off the sleep mode so that GPS module will not be power off and try again?
As i know, the GPS accuracy issue has been fixed. More details you can have a look at the above messages in this topic.
i am using TTN server, so TTN itself giving me converted values.
thanks for the reply.
I have disabled the sleep mode and the gps_timeout is 100.
Still i am not getting accurate GPS location.
Can you please tell me the GPS accuracy in radius.
Thanks again!!!
As we tested, the GPS accurate is around 10 meters.
I can confirm the result and findings of @Fomi
I know that the difference is on the negative, but I can’t found how to convert.
If anyone help me…
The data is in the standard Cayenne LPP format, here’s a link to the packet format.
You also need to factor in that the data is encoded in base64 in the packet.
