This is a newly purchased RAK7200 which came with firmware 3.1.0.13 pre-installed and boot firmware 3.1.1. I also noticed it arrived preconfigured in P2P work mode.
I read in the 3.1.0.13 release notes that P2P mode isn’t supported on this device, so the config options were removed relating to it.
Feature:
1.delete LoRaP2P AT command because RAK7200 don’t support LoRaP2P mode
The problem is, the at+set_config=lora:work_mode:X command is not accepted as a valid command anymore.
I tried downgrading to 3.1.0.12, but after booting - “Initialization OK,current work_mode:P2P” I get no output reply from any AT commands I send. I was hoping to change the work mode on version 3.1.0.12 and then upgrade back to 3.1.0.13. I’ve also tried 3.1.0.11, I have the same problem as I do with 3.1.0.12.
Hi @shanemau Can you try to reflash both the bootloader and firmware of RAK7200. Please first erase the chip before flashing the bootloader. Also, can you PM me your order number to check this purchase.
My problem was resolved with the help of @Nicholas via DM, thank you. Message him if you are facing the same problem as I cannot share the command publicly.
Hi @mkdevch This behavior affects some RAK7200 devices already shipped. You can use the at+set_config=lora:normal AT command to set the work mode back to LoRaWAN.
