RAK7204 Not able to use
Nice to know it is working now. Most likely it is the cable :slight_smile:
Also, you don’t need to reflash it. It should work right out of the box.
Thank you @carlrowan hinting me the 3.3V, I have made additional investigation and it seems that real problem was that the battery of RAK7204 wasn’t correctly connected. So one has to be sure that it sticks correctly and device is operating before it is connected to USB. W/o battery correctly connected it behaves as described above.
Hello ,
I recently bought a new 7204 Weather Sensor.
Out of the box it has 1 jumper installed only .
Is that correct?
Also , trying to set it up for Helium Console and when getting the EUI keys etc in Serial Port Tool all I’m seeing is the error messages : “too few parameters”
I have no idea what that means .
Has anyone seen this ?
Thnx , Michael
Hi @StJam Yes, only one jumper should be on the PCB.
Can you show what command you issued before getting the error?
