The antenna labels are correct. Those antenna are unbalance and greatly affected by the surrounding materials. The resonant frequency can change just by touching it.
Can you test again the resonant frequency while the antenna is attached on the enclosure?
Battery and solar connected, and enclosure closed as far as possible. Antenna is stuck internally to the side of the enclosure like recommended in the assembly guide.
