Hi, I have an updated RAK7205.
BOOT: RUI_RAK5205_BOOT_Version3_0_2
FIRMWARE: RUI_RAK5205_V3.0.0.12.H.T1(EU868-US915-AU915-KR920-IN865)
I purchased this tracker last year, and already with the 2.0.x firmware I noticed a problem with temperature readings, they are highter than 4°C.
No software / hardware changes, I use TTN and I read the data on Cayenne, I followed the documentation step by step.
I have read some other similar problems with the BME680, regarding the heating of the gas resistance.
I have the same problem. However BME680 works with RUI_RAK5205_V3.0.0.12.L.T1(EU433-CN470) firmware. @velev I’m using USB power. My node doesn’t have a battery. Is that the issue with EU868?
I also noticed that 7205 reports a +2 or +3 temperature than the air temperature. I think it is because of the plastic enclosure - it is airtight/waterproof. So it will probably report the temperature of the inside air.
The device will keep the internal temperature warm - there is the possibility that it could keep the internal temperature +20 degrees or more. I’ve had devices with -50℃ external temperature reporting +10℃ in the box.
