RAK7240 - does it support 802.3at PoE+
Hey Everyone,
We are in process of selecting suitable PoE injector for the RAK7240 (specifically one that works on 12volt battery voltage range.)
I note that RAK states the RAK7240 draws about 12watts BUT the specification on the RAK website states is 802.3.af complaint - which is only up to around 16watts from the PSU and only 13watts at the device, but the mains PoE OEM supplied in the box with the gateway is 24watts e.g. 802.3at specification I believe.
I intend to use the following which appears to match the voltage input range that the RAK supports of 42volts to 56volts pointing towards both being 802.3at spec.
Please confirmed that there wont be any issues:
Toby
