I’m testing a RAK7243C with LTE gateway. Everything seems to work fine BUT.
Every 24 hours GSM data in ppp0 go back to 4 bytes (4 in and 4 out).
When this issue occurs the gateway appears disconnected in TTN Console.
- ping www.google.fr doesn’t give ping back.
- By killing process using AMA serial port and quickly connecting through minicom or with pppd call gprs everything seems to be fine.
- Sim card works great in other gateway brand with same network and settings.
The solution is rebooting. sudo reboot correct the problem. But I can’t stand behind the screen everyday. And I need to setup this gateway without screen or keyboard.
Is it possible to build a reliable gateway with this setup???
Thanks a lot.
