RAK7244 - DHCP LAN
Issue: Mandatory Static IP Address
The RAK 7244 requires a static ip address, is not possible for it to just use DHCP and have a dynamic ip address assigned ?
It doesn’t really say mandatory, it’s just the setup shows setting up with a static address - which makes things rather convenient for ssh’ing in for admin purposes.
Otherwise, it’s just a Pi, plenty of instructions on line for setting up as DHCP - which I suspect if you don’t try to set a static address it will actually do anyway.
