During this test modem was not connected to ethernet and wifi . It was working in AP mode . Please clarify how it should work in LTE .
And
is it possible to use the LTE and access the wifi internet on external devices via AP mode of 7249
1.power off your device, insert SIM card, power on your device.
2.from this picture, i find you didn’t set APN,please set APN of your card provider. then, restart your device.
3.if all of above is ok,the device now works on LTE.
LTE mode and wifi Client mode cannot work at the same time.
if you want LTE mode and wifi AP mode, you should do as follow:
firstly,make sure your device work on LTE mode.
then, set AP mode as wifi mode, and set wifi ssid ,etc.
Thanks, @Nicholas for this solution. Actually, I am also searching for the same solution for my LTE modem, now I will try to follow these given instructions.
One thing please confirm that is client mode also called bridge mode?
Tried the same changes @Nicholas , I disabled the wifi interface and access the device over ethernet . Since i am using salt simcard in Switzerland , so entered the APN as “internet” and user,password entries kept blank. After saving all settings reboot the modem but the result is same it does not connect on cellular interface at all.
Yes @Nicholas sure about the APN, since with the same APN “internet” works on my phone and on another 4G hotspot device also. My gateway is already connected to internet via ethernet interface, and wifi interface was disabled, will it connect on cellular services with these settings. I believe it should show alteast the network name on dashboard. But nothing it remains same as screenshot shared in my first post.
Please suggest solution for this, or shall i change another telecom service provider if this may help.
Mine does the following here in Bulgaria. I insert the card. No APN, no user or password, everything is blank. As a matter of fact is was set to work in AP mode even before inserting the card.
I plug the ethernet cable it works. I unplug it it keeps working over the LTE. It get the address via DHCP for the Cellular and it is displayed in the overview page. Maybe it is due to my carrier, however have you tried to leave everything blank?
Can you share what firmware version you are using. I am using:
After further testing my RAK7249 works flawlessly. Leaving the APn empty and well as filling in the APN of my provider results in the Gateway acquiring an IP address and forwarding packets.
Could you please try leaving the field blank, or trying “Internet*” as the APN name.
Perhaps you have solved the issues in the meantime ?
I have tried with Salt and MBudget Sim cards in Switzerland, but no success. I always get the same status as above.
Yes my firmware version is same as yours : 1.1.0037_Release r159
Sorry for not solving the issues already. Could you please update to the latest version and post the logs after. We are working on it, you have not been ignored. It is simply the fact that we can’t replicate the issues, as all SIM providers we have at our disposal seem to not cause this problem.
Please use the link and let me know how it goes: https://downloads.rakwireless.com/en/LoRa/DIY-Gateway-RAK7249/Firmware/
