Issue:I save my RAK configuration ( download ) to a config file as a backup, then when some changes are made and it does not work I can revert by uploading the config file. The problem is that in the Lora Application Settings, The Devices that I have added using OTAA Show DEVID as “Blank” and the only way for them to reactivate is to reset them all to rejoin.
Setup:I setup my RAKto connect to a broker, I add a Device LSN50 sensor with 2 x DS18B20’s MOD=4, The Device Activates , I get data on the broker, All working, I download the config file, then I upload that same config file, The connected devices do not reconecct I get no data,
LoRa® Server:RAK7258
Details: 1.2.0066_Release r213
