Hello and Good Day,
My RAK7258 gateway is not connected to the TTN. It is setup correctly and i can see packets from all around me arriving at the gateway including my own node nearby. However, this data from this specific gateway is not being fowarded to the TTN. I have double checked the server adresses and API keys and selected the configuration of the gateway as packet fowarder but from the TTN, it shows disconnected and does not seem to connect. It is frustrating to say the least but any help would be greatly appreciated.
I do not know why i did not think of this. Thank you both Vladislav and Nick for the help. The gateway packets are now being fowarded to the TTN.
Also this may not be related to the current topic but the gateway web management platform was not accesible for some time yesterday causing me to perform a factory resest and re-configure it again. The error recieved from the IP address is shown in the picture below. Is there some idea as to what causes this and how to fix it such that one does not always perform a factory reset when it happens again in the future ?
@Larry can you share the firmware version you are using? This is an old bug fixed in the latest version of the WisGateOS. The latest firmware can be found here.
Hi Velev, I am using version ‘1.2.0066_Release r213’. I should upload the bin file from the firmware attachment in your previous comment as a update ?
Regards,
Larry.
