RAK7258 weak coverage
The last days I had some time to setup my RAK7258 gateway and lora nodes RAK7205. The TTN setup was straight forward and easy to handle.
Gateway is on the latest firmware 1.1.0045_Release r176 and I use Power over Ethernet.
The maximum range I could get with TTN mapper was 300m. So I tested the Nodes in an urban area and successfully transmitted packages over 3 KM. So the Node is not the problem.
When I remove the antenna from the gateway the coverage is only a view meters. So it looks like the antenna is working.
Maybe there is a problem with the Firmware / Hardware / Configuration?
Any ideas?
Hi @Agrikula,
First of all the latest firmware is r180, this should not matter, but better to be up to date.
Can you give us a little more context :freq band, power settings, nodes, channels, etc.
Perhaps some logs.
Vladislav
Thank you for the fast reply!
Will test also with the new Firmware.
I use the TTN 868MHz EU Band.
TTN Server: router.eu.thethings.network Semtech UDP
The Node is a RAK7205 with AT firmware 3.0.0.3.H
I will send some logs when I am on site.
Hi @Agrikula,
Thank you, would love to check the logs, on first glance however I see you are using 867.4MHz, which is not a part of the eu868 ttn plan. Also you are missi g the 867.9MHz. Start by setting the gateway plan properly and we will seem what comes next :slight_smile:
Firmware update done :+1:
Reconfigured TTN EU868 frequency plan and rebooted gateway :+1:
At the moment the distance is 300m (inhouse standard windows)
Node LOG:
[LoRa]: LORA_EVENT_UNKNOWN 4
Go to Sleep.
Wake up.
Battery Voltage = 4.200 V
ACC X: 0 mg, Y: -256 mg, Z: -256 mg
Humidity:48.0 %RH
pressure:993.0 hPa
Temperature:27.0 degree
[LoRa]: Send out
Go to Sleep.
Gateway LOG:
Fri Aug 16 20:22:29 2019 user.info lora_pkt_fwd[8242]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
JSON up: {“stat”:{“time”:“2019-08-16 18:22:29 UTC”,“lati”:48.xxxxx,“long”:16.xxxxx,“alti”:210,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“cpur”:0.0,“memr”:0.0}}
Fri Aug 16 20:22:29 2019 user.info lora_pkt_fwd[8242]: INFO: [up] PUSH_ACK received in 58 ms
Fri Aug 16 20:22:51 2019 user.info lora_pkt_fwd[8242]: INFO: Received pkt CRC BAD
Fri Aug 16 20:22:52 2019 user.info lora_pkt_fwd[8242]: INFO: [down] PULL_ACK received in 54 ms
Fri Aug 16 20:22:57 2019 user.info lora_pkt_fwd[8242]: INFO: [down] PULL_ACK received in 53 ms
Fri Aug 16 20:22:59 2019 user.info lora_pkt_fwd[8242]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
JSON up: {“stat”:{“time”:“2019-08-16 18:22:59 UTC”,“lati”:48.xxxxx,“long”:16.xxxxx,“alti”:210,“rxnb”:1,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“cpur”:0.0,“memr”:0.0}}
Fri Aug 16 20:22:59 2019 user.info lora_pkt_fwd[8242]: INFO: [up] PUSH_ACK received in 55 ms
Hi @Agrikula,
I was hoping to see the rssi and channel of the frames, can you provide that data.
Vladislav
Hi! Hope you had a good weekend!
Here are the Gateway logs. Node is 40m away.
This are the values of the Node 300m away (line of sight).
