Hi All,
Major bug report here for the LoRa Concentrator section of the GUI for Advanced Setup:
Updating gateway to WisGateOS 1.1.1 on either the RAK7258 OR RAK7240 causes the Advanced Mode section of the LoRa Concentrator section to fail to save correctly.
I am able to enter SF0/SF7, STD and FSK offsets etc to change frequency details in full, BUT as soon as the Apply/Save is hit all these revert back - no way to save it correctly (at least through the GUI)
This has been to found to affect EU868, AU915 and AS923 versions we have of the 7258/7240 gateway running software version for example on RAK258: 1.1.1_RAK rRAK-c7679acc7 etc.
Reverting to 1.0.2_RAK rRAK-3940b904c for RAK7258 solves the issue (AS923 / AS1 tested)
Reverting to 1.0.2_RAK rRAK-3940b904c for RAK7240 solves the issue also. (EU868 tested)
Note the basic layout “Switch to Standard Mode” seams to be OK (not fully tested), however this is the reason it has been discovered due to wanting to set AS1/AS920-923 on a AS923 gateway instead of AS2, there is no drop-down to preset to AS1 (correct me if I am wrong).
For our production/integration we have quarantined the 1.1.1 firmware as it doesn’t improve on the last version, 1.0.2 will be all we use.
Toby
