Issue: The RAK7268 is configured as a basic station with LNS server type and TLS Server and Client Authentication with the AWS IoT service. The configuration is done via the WisDM platform. After assigning the gatway, it properly connects and works fine. After a power outage, the connection is not re-established. The same problem occurs if rebooting the RAK device via WisDM. In order to re-establish the connection, I have to unassign the gateway, and re-assign it.
Setup: RAK7268 with firmware version 1.3.4
LoRa® Server: AWS IoT
Details: I checked the running process on the gateway, when the conection is working, I can see this process:
/usr/bin/lbs/station --home /var/etc/station --temp /var/run
After rebooting, it is not running, so my assumption is that something is missing in the /etc/init.d scripts.
Thanks for the help.
Antoine Lefebvre
