What is the console port on the RAK7268 used for? What are the serial port settings (i.e. baud rate) for this port?
Thanks!
Thanks!
Baud Rate is 57600
In Windows the COM port will show up with a name like USB_SERIAL CH340
I have used PuTTY and TeraTerm and both work with standard serial settings.
If you are seeing boot issues, this is the only way to see things before the SSH service comes up
You can also run most shell after logging in over the console. Reminder that RAK OS is based on OpenWRT OS. If you need to find shell commands the OpenWRT docs are great.
