We are attempting to get our RAK7268 gateway working on LTE. We have configured the cell with the APN given to us by our LTE provider but the SIM appears to not be able to establish a connection with the internet. I have attached screenshots of our configuration as well as our system log file. Is there any additional configuration that may be required?
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Find /sys/bus/usb/devices/1-1 idVendor=2c7c idProduct=0195
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Find /sys/bus/usb/devices/1-1:1.4/net/wwan0
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Find usbnet_adapter = wwan0
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Find /sys/bus/usb/devices/1-1:1.4/usbmisc/cdc-wdm0
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Find qmichannel = /dev/cdc-wdm0
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: cdc_wdm_fd = 7
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Get clientWDS = 20
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Get clientDMS = 1
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Get clientNAS = 4
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Get clientUIM = 1
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: Get clientWDA = 1
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: requestBaseBandVersion EG95NAFBR05A04M4G
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: requestGetSIMStatus SIMStatus: SIM_READY
Wed Oct 20 17:56:16 2021 kern.info quectel-CM[23337]: requestGetICCID DeviceICCID: 89148000006975364355
Wed Oct 20 17:56:17 2021 kern.info quectel-CM[23337]: requestGetIMSI DeviceIMSI: 311270014417679
Wed Oct 20 17:56:17 2021 kern.info quectel-CM[23337]: requestSetProfile[1] wyleslte.gw7.vzwentp///0
Wed Oct 20 17:56:17 2021 kern.info quectel-CM[23337]: requestGetProfile[1] wyleslte.gw7.vzwentp///0
Wed Oct 20 17:56:17 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:17 2021 kern.info quectel-CM[23337]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Wed Oct 20 17:56:17 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:17 2021 kern.info quectel-CM[23337]: Dail Failed 1
Wed Oct 20 17:56:22 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:22 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:22 2021 kern.info quectel-CM[23337]: Dail Failed 2
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]:
2021-10-20 17:56:23 UTC
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: ### [UPSTREAM] ###
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets received by concentrator: 0
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets forwarded: 0 (0 bytes)
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA acknowledged: 100.00
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: ### [DOWNSTREAM] ###
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # PULL_DATA sent: 6 (100.00 acknowledged)
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets sent to concentrator: 0 (0 bytes)
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # SX1301/SX1302 time (PPS): 2323479776, offset us 0
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: ### [GPS] ###
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: # GPS sync is disabled
Wed Oct 20 17:56:23 2021 user.notice lora_pkt_fwd[2103]: ##### END #####
Wed Oct 20 17:56:27 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:27 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:27 2021 kern.info quectel-CM[23337]: Dail Failed 3
Wed Oct 20 17:56:32 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:32 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:32 2021 kern.info quectel-CM[23337]: Dail Failed 4
Wed Oct 20 17:56:37 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:37 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:37 2021 kern.info quectel-CM[23337]: Dail Failed 5
Wed Oct 20 17:56:42 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:42 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:42 2021 kern.info quectel-CM[23337]: Dail Failed 6
Wed Oct 20 17:56:47 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:47 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:47 2021 kern.info quectel-CM[23337]: Dail Failed 7
Wed Oct 20 17:56:52 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:52 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:52 2021 kern.info quectel-CM[23337]: Dail Failed 8
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]:
2021-10-20 17:56:53 UTC
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: ### [UPSTREAM] ###
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # RF packets received by concentrator: 1
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # CRC_OK: 0.00, CRC_FAIL: 100.00, NO_CRC: 0.00
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # RF packets forwarded: 0 (0 bytes)
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA acknowledged: 100.00
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: ### [DOWNSTREAM] ###
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # PULL_DATA sent: 6 (100.00 acknowledged)
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # RF packets sent to concentrator: 0 (0 bytes)
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # SX1301/SX1302 time (PPS): 2353480823, offset us 0
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: ### [GPS] ###
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: # GPS sync is disabled
Wed Oct 20 17:56:53 2021 user.notice lora_pkt_fwd[2103]: ##### END #####
Wed Oct 20 17:56:57 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:56:57 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:56:57 2021 kern.info quectel-CM[23337]: Dail Failed 9
Wed Oct 20 17:57:03 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:57:03 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:57:03 2021 kern.info quectel-CM[23337]: Dail Failed 10
Wed Oct 20 17:57:08 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:57:08 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:57:08 2021 kern.info quectel-CM[23337]: Dail Failed 11
Wed Oct 20 17:57:13 2021 kern.info quectel-CM[23337]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:57:13 2021 kern.info quectel-CM[23337]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:57:13 2021 kern.info quectel-CM[23337]: Dail Failed 12
Wed Oct 20 17:57:16 2021 kern.info quectel-CM[23337]: QmiWwanThread exit
Wed Oct 20 17:57:16 2021 kern.info quectel-CM[23337]: main exit
Wed Oct 20 17:57:19 2021 kern.info quectel-CM[28197]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Wed Oct 20 17:57:19 2021 kern.info quectel-CM[28197]: /usr/sbin/quectel profile[1] = wyleslte.gw7.vzwentp///0, pincode = (null)
Wed Oct 20 17:57:19 2021 user.notice root: echo 1 > /sys/class/gpio/gpio42/value
Wed Oct 20 17:57:20 2021 daemon.notice netifd: Network device ‘wwan0’ link is down
Wed Oct 20 17:57:20 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Wed Oct 20 17:57:20 2021 daemon.notice netifd: Interface ‘wwan6’ has link connectivity loss
Wed Oct 20 17:57:20 2021 daemon.notice netifd: wwan (24390): Read error: Network is down, reopening socket
Wed Oct 20 17:57:20 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Wed Oct 20 17:57:20 2021 daemon.notice netifd: Interface ‘wwan6’ is disabled
Wed Oct 20 17:57:20 2021 daemon.notice netifd: wwan (24390): udhcpc: bind: No such device
Wed Oct 20 17:57:20 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:57:20 2021 user.notice root: echo 0 > /sys/class/gpio/gpio42/value
Wed Oct 20 17:57:21 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]:
2021-10-20 17:57:23 UTC
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: ### [UPSTREAM] ###
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets received by concentrator: 2
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # CRC_OK: 50.00, CRC_FAIL: 50.00, NO_CRC: 0.00
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets forwarded: 1 (23 bytes)
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA datagrams sent: 2 (342 bytes)
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA acknowledged: 100.00
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: ### [DOWNSTREAM] ###
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # PULL_DATA sent: 6 (100.00 acknowledged)
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets sent to concentrator: 0 (0 bytes)
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # BEACON queued: 0
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # BEACON sent so far: 0
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # BEACON rejected: 0
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: ### [JIT] ###
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # SX1301/SX1302 time (PPS): 2383481875, offset us 0
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: ### [GPS] ###
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: # GPS sync is disabled
Wed Oct 20 17:57:23 2021 user.notice lora_pkt_fwd[2103]: ##### END #####
Wed Oct 20 17:57:34 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Wed Oct 20 17:57:34 2021 daemon.notice netifd: Interface ‘wwan6’ is enabled
Wed Oct 20 17:57:34 2021 daemon.notice netifd: Network device ‘wwan0’ link is up
Wed Oct 20 17:57:34 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Wed Oct 20 17:57:34 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Wed Oct 20 17:57:34 2021 daemon.notice netifd: Interface ‘wwan6’ has link connectivity
Wed Oct 20 17:57:34 2021 daemon.notice netifd: Interface ‘wwan6’ is setting up now
Wed Oct 20 17:57:35 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:57:35 2021 daemon.notice netifd: wwan (29247): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Wed Oct 20 17:57:35 2021 daemon.notice netifd: wwan (29247): udhcpc (v1.23.2) started
Wed Oct 20 17:57:35 2021 daemon.notice netifd: wwan (29247): Sending discover…
Wed Oct 20 17:57:36 2021 daemon.info db[1988]: DataBase Backup
Wed Oct 20 17:57:37 2021 kern.info quectel-CM[29466]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Wed Oct 20 17:57:37 2021 kern.info quectel-CM[29466]: /usr/sbin/quectel profile[1] = wyleslte.gw7.vzwentp///0, pincode = (null)
Wed Oct 20 17:57:37 2021 user.notice root: echo 1 > /sys/class/gpio/gpio42/value
Wed Oct 20 17:57:38 2021 daemon.notice netifd: Network device ‘wwan0’ link is down
Wed Oct 20 17:57:38 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Wed Oct 20 17:57:38 2021 daemon.notice netifd: Interface ‘wwan6’ has link connectivity loss
Wed Oct 20 17:57:38 2021 daemon.notice netifd: wwan (29247): Read error: Network is down, reopening socket
Wed Oct 20 17:57:38 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Wed Oct 20 17:57:38 2021 daemon.notice netifd: Interface ‘wwan6’ is disabled
Wed Oct 20 17:57:38 2021 daemon.notice netifd: wwan (29247): udhcpc: bind: No such device
Wed Oct 20 17:57:38 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:57:38 2021 user.notice root: echo 0 > /sys/class/gpio/gpio42/value
Wed Oct 20 17:57:39 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:57:43 2021 kern.info quectel-CM[29919]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Wed Oct 20 17:57:43 2021 kern.info quectel-CM[29919]: /usr/sbin/quectel profile[1] = wyleslte.gw7.vzwentp///0, pincode = (null)
Wed Oct 20 17:57:43 2021 user.notice root: echo 1 > /sys/class/gpio/gpio42/value
Wed Oct 20 17:57:43 2021 user.notice esw: esw link state changed : down - ifup wan
Wed Oct 20 17:57:44 2021 daemon.notice netifd: wan (1968): Received SIGTERM
Wed Oct 20 17:57:44 2021 daemon.notice netifd: Interface ‘wan’ is now down
Wed Oct 20 17:57:44 2021 daemon.notice netifd: Interface ‘wan’ is setting up now
Wed Oct 20 17:57:44 2021 daemon.notice netifd: Network device ‘ra0’ link is down
Wed Oct 20 17:57:45 2021 user.notice root: echo 0 > /sys/class/gpio/gpio42/value
Wed Oct 20 17:57:45 2021 daemon.notice netifd: wan (30020): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Wed Oct 20 17:57:45 2021 daemon.notice netifd: wan (30020): udhcpc (v1.23.2) started
Wed Oct 20 17:57:45 2021 daemon.notice netifd: wan (30020): Sending discover…
Wed Oct 20 17:57:45 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Wed Oct 20 17:57:45 2021 daemon.notice netifd: Interface ‘wan0’ has link connectivity loss
Wed Oct 20 17:57:45 2021 daemon.notice netifd: Interface ‘wan06’ has link connectivity loss
Wed Oct 20 17:57:45 2021 daemon.notice netifd: wan0 (1779): Read error: Network is down, reopening socket
Wed Oct 20 17:57:46 2021 daemon.notice netifd: wan0 (1779): udhcpc: sendto: Network is down
Wed Oct 20 17:57:46 2021 daemon.notice netifd: wan0 (1779): Received SIGTERM
Wed Oct 20 17:57:46 2021 kern.info quectel-CM[28197]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Wed Oct 20 17:57:48 2021 daemon.notice netifd: wan (30020): Sending discover…
Wed Oct 20 17:57:48 2021 user.notice esw: esw link state changed : up - ifup wan
Wed Oct 20 17:57:50 2021 daemon.notice netifd: radio0 (30106): Interface doesn’t accept private ioctl…
Wed Oct 20 17:57:50 2021 daemon.notice netifd: radio0 (30106): set (8BE2): Invalid argument
Wed Oct 20 17:57:50 2021 daemon.notice netifd: wan (30020): Received SIGTERM
Wed Oct 20 17:57:50 2021 daemon.notice netifd: Interface ‘wan’ is now down
Wed Oct 20 17:57:50 2021 daemon.notice netifd: Interface ‘wan’ is setting up now
Wed Oct 20 17:57:50 2021 daemon.notice netifd: Network device ‘ra0’ link is up
Wed Oct 20 17:57:51 2021 daemon.notice netifd: wan (30281): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Wed Oct 20 17:57:51 2021 daemon.notice netifd: wan (30281): udhcpc (v1.23.2) started
Wed Oct 20 17:57:51 2021 daemon.notice netifd: wan (30281): Sending discover…
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]:
2021-10-20 17:57:53 UTC
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: ### [UPSTREAM] ###
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # RF packets received by concentrator: 0
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # RF packets forwarded: 0 (0 bytes)
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA acknowledged: 100.00
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: ### [DOWNSTREAM] ###
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # PULL_DATA sent: 6 (100.00 acknowledged)
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # RF packets sent to concentrator: 0 (0 bytes)
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # TX errors: 0
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # BEACON queued: 0
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # BEACON sent so far: 0
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # BEACON rejected: 0
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: ### [JIT] ###
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # SX1301/SX1302 time (PPS): 2413483398, offset us 0
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: ### [GPS] ###
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: # GPS sync is disabled
Wed Oct 20 17:57:53 2021 user.notice lora_pkt_fwd[2103]: ##### END #####
Wed Oct 20 17:57:54 2021 daemon.notice netifd: wan (30281): Sending discover…
Wed Oct 20 17:57:57 2021 daemon.notice netifd: wan (30281): Sending discover…
Wed Oct 20 17:57:58 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Wed Oct 20 17:57:58 2021 daemon.notice netifd: Interface ‘wwan6’ is enabled
Wed Oct 20 17:57:58 2021 daemon.notice netifd: Network device ‘wwan0’ link is up
Wed Oct 20 17:57:58 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Wed Oct 20 17:57:58 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Wed Oct 20 17:57:58 2021 daemon.notice netifd: Interface ‘wwan6’ has link connectivity
Wed Oct 20 17:57:58 2021 daemon.notice netifd: Interface ‘wwan6’ is setting up now
Wed Oct 20 17:57:59 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:57:59 2021 daemon.notice netifd: wwan (30817): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Wed Oct 20 17:57:59 2021 daemon.notice netifd: wwan (30817): udhcpc (v1.23.2) started
Wed Oct 20 17:57:59 2021 daemon.notice netifd: wwan (30817): Sending discover…
Wed Oct 20 17:58:00 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:58:02 2021 daemon.notice netifd: wwan (30817): Sending discover…
Wed Oct 20 17:58:05 2021 daemon.notice netifd: wwan (30817): Sending discover…
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29919]: Find /sys/bus/usb/devices/1-1 idVendor=2c7c idProduct=0195
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29919]: Find /sys/bus/usb/devices/1-1:1.4/net/wwan0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29919]: Find usbnet_adapter = wwan0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29919]: Find /sys/bus/usb/devices/1-1:1.4/usbmisc/cdc-wdm0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29919]: Find qmichannel = /dev/cdc-wdm0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29466]: Find /sys/bus/usb/devices/1-1 idVendor=2c7c idProduct=0195
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29466]: Find /sys/bus/usb/devices/1-1:1.4/net/wwan0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29466]: Find usbnet_adapter = wwan0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29466]: Find /sys/bus/usb/devices/1-1:1.4/usbmisc/cdc-wdm0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29466]: Find qmichannel = /dev/cdc-wdm0
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29919]: cdc_wdm_fd = 7
Wed Oct 20 17:58:09 2021 kern.info quectel-CM[29466]: cdc_wdm_fd = 7
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: Get clientWDS = 20
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: Get clientDMS = 1
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: Get clientNAS = 4
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: Get clientUIM = 1
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: Get clientWDA = 1
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestBaseBandVersion EG95NAFBR05A04M4G
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestGetSIMStatus SIMStatus: SIM_READY
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestGetICCID DeviceICCID: 89148000006975364355
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestGetIMSI DeviceIMSI: 311270014417679
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestSetProfile[1] wyleslte.gw7.vzwentp///0
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestGetProfile[1] wyleslte.gw7.vzwentp///0
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29466]: Dail Failed 1
Wed Oct 20 17:58:10 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:12 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:14 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:16 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:18 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:20 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:22 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]:
2021-10-20 17:58:23 UTC
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: ### [UPSTREAM] ###
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets received by concentrator: 1
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # CRC_OK: 100.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets forwarded: 1 (23 bytes)
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA datagrams sent: 2 (343 bytes)
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # PUSH_DATA acknowledged: 100.00
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: ### [DOWNSTREAM] ###
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # PULL_DATA sent: 5 (100.00 acknowledged)
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # RF packets sent to concentrator: 0 (0 bytes)
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # SX1301/SX1302 time (PPS): 2443484652, offset us 0
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: ### [GPS] ###
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: # GPS sync is disabled
Wed Oct 20 17:58:23 2021 user.notice lora_pkt_fwd[2103]: ##### END #####
Wed Oct 20 17:58:24 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:26 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:28 2021 kern.info quectel-CM[29919]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Wed Oct 20 17:58:29 2021 kern.info quectel-CM[29919]: main Failed to QmiWwanInit: 2 (No such file or directory)
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[32481]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[32481]: /usr/sbin/quectel profile[1] = wyleslte.gw7.vzwentp///0, pincode = (null)
Wed Oct 20 17:58:32 2021 user.notice root: echo 1 > /sys/class/gpio/gpio42/value
Wed Oct 20 17:58:32 2021 daemon.notice netifd: Network device ‘wwan0’ link is down
Wed Oct 20 17:58:32 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Wed Oct 20 17:58:32 2021 daemon.notice netifd: Interface ‘wwan6’ has link connectivity loss
Wed Oct 20 17:58:32 2021 daemon.notice netifd: wwan (30817): Read error: Network is down, reopening socket
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: QmiWwanThread poll err/hup/inval
Wed Oct 20 17:58:32 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Wed Oct 20 17:58:32 2021 daemon.notice netifd: Interface ‘wwan6’ is disabled
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: poll fd = 7, events = 0x0018
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: requestQueryDataCall err = 0
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: QmiWwanSendQMI cdc_wdm_fd = -1
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: requestRegistrationState2 err = -19
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: Dail Failed 2
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: QmiWwanThread exit
Wed Oct 20 17:58:32 2021 kern.info quectel-CM[29466]: main exit
Wed Oct 20 17:58:32 2021 daemon.notice netifd: wwan (30817): udhcpc: bind: No such device
Wed Oct 20 17:58:32 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:58:33 2021 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Wed Oct 20 17:58:33 2021 user.notice root: echo 0 > /sys/class/gpio/gpio42/value
