I have a problem with my gateway 7268. I have tried to update the firmware and now I can’t to connect by ethernet or wifi.
I have tried to press the reset button for more than 5 seconds to reset it to factory settings but it does not work.
I’ve connected through the console port with putty, but I don’t know what I can do from here to get it back. Is it possible to perform a reset from here?
I had the same problem with RAK7268. If your Breathing Led is OFF, that means you are not able to connect RAK with Wi-Fi nor Ethernet. Here are the guides on how to perform a recovery:
