I have a RAK7268 that is connected and registered with AWS Core IOT and it worked as expected for a while.
I recently removed it to another site and connected it to the network at that site.
I can see that the GW is identify by AWS so I guess the network connection is working fine.
But, from some reason, the GW does not receive any more the transitions that are sending from a edge device that I’m working with (They are sitting on the same desk).
I can see many error message in the log but I’m not sure I understand what changed as I only moved the GW to a different site and I’m using the same edge unit that was successfully working on the initial site with this GW.
Here are some errors I can see in the log:
Mon May 16 13:02:32 2022 user.debug basicstation[1751]: [TCE:VERB] Connecting to MUXS…
Mon May 16 13:02:34 2022 user.debug basicstation[1751]: [TCE:VERB] Connected to MUXS.
Mon May 16 13:02:34 2022 kern.info ap_client: apcli0 is not associated
Mon May 16 13:02:34 2022 kern.info ap_client: Scanning for networks…
Mon May 16 13:02:35 2022 user.warn basicstation[1751]: [S2E:WARN] Unknown field in router_config - ignored: protocol (0xFD309030)
Mon May 16 13:02:35 2022 user.warn basicstation[1751]: [S2E:WARN] Unknown field in router_config - ignored: regionid (0xE6FFB211)
Mon May 16 13:02:35 2022 user.debug basicstation[1751]: [SYS:VERB] /etc/station/radio_init.sh: Forked, waiting…
Mon May 16 13:02:35 2022 user.err basicstation[1751]: [SYS:ERRO] Process /etc/station/radio_init.sh (pid=6373) did not terminate within 200ms - killing it (SIGTERM)
Mon May 16 13:02:35 2022 user.err basicstation[1751]: [RAL:ERRO] ral_config failed with status 0x04
Mon May 16 13:02:35 2022 user.err basicstation[1751]: [any:ERRO] Closing connection to muxs - error in s2e_onMsg
Mon May 16 13:02:36 2022 user.debug basicstation[1751]: [TCE:VERB] Connection to MUXS closed in state -1
Mon May 16 13:02:36 2022 user.info basicstation[1751]: [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
Mon May 16 13:02:36 2022 user.warn basicstation[1751]: [LOG:WARN] LoRa modulation error: 0
Mon May 16 13:02:37 2022 user.info basicstation[1751]: [LOG:INFO] dutycycle size: 63738
Mon May 16 13:02:37 2022 user.crit basicstation[1751]: [SYN:CRIT] SX130X time sync roll over - no update for a long time!
Mon May 16 13:02:37 2022 user.info basicstation[1751]: [SYN:INFO] Time sync qualities: min=88 q90=154 max=639 (previous q90=2147483647)
Mon May 16 13:02:39 2022 user.err basicstation[1751]: [SYN:ERRO] SX130X#0 trigger count not ticking or weird value: 0xD5000100000000 … 0xD5000100000000 (dxc=0)
Mon May 16 13:02:39 2022 kern.info ap_client: Found network - 11 OrlyY 60:38:e0:04:f7:80 WPA1PSKWPA2PSK
Mon May 16 13:02:39 2022 kern.info ap_client: No signal found to connect to
Mon May 16 13:02:41 2022 user.err basicstation[1751]: [SYN:ERRO] SX130X#0 trigger count not ticking or weird value: 0xD5000100000000 … 0xD5000100000000 (dxc=0)
Mon May 16 13:02:43 2022 user.err basicstation[1751]: [SYN:ERRO] SX130X#0 trigger count not ticking or weird value: 0xD5000100000000 … 0xD5000100000000 (dxc=0)
