After powering on the RAK7268 gateway, Basics Station cannot connect to TTN if OpenVPN is enabled. However, the OpenVPN connection works properly, the device is reachable.
When I go to the Menu ‘LoRa Network → Network Settings’ and press ‘Save’, the gateway immediatly connects to TTN.
I suppose there is a routing or start up problem with Basics Station. Any suggestions what could be the issue?
I am new at RAK but there is a similar problem with our RAK7268. We have the same firmware 1.3.4 and when we power of, GW cannot connect to TTN. We restart the GW to reconnect to TTN. If we turn off and turn it on, GW cannot connect. Yesterday, someone told me that there is a bug at 1.3.4 version. He said that we had to downgrade the firmware to 1.3.3. I do not know this is true but this is the story. I hope our problems will be solved.
