Issue:
Downlink message is been dropped by the gateway which is preventing it from receiving joinAccept or any downlink message.
Setup:
firmware version : 1.3.5_RAK b135
Server:
Aws Iot core lorawan
Details:
I just got this new Rak7268 gateways which came with firmware version 1.3.5 onboard and am using the BaseStation mode to connect to aws iot core lorawan network, connecting the gateway to the server is working fine, but when an end node try to join network the gateway never receive the joinaccept downlink from the server, i checked and confirm that aws is sending the JoinAccept message. it seems like the message is been dropped by the gateway, below is the systemLog from the gateway, any ideas on how i can resolve this issue?
ri Nov 18 14:02:34 2022 kern.info kernel: [ 7439.900000] syslog.sh (2486): drop_caches: 1
Fri Nov 18 14:02:39 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:02:42 2022 user.notice data-broker: data-broker timeout, restart it
Fri Nov 18 14:02:45 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:02:52 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:02:58 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:05 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:12 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:17 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:25 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:30 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:37 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:43 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:50 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:03:57 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:03 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:09 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:16 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:22 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:28 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:35 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:42 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:48 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:04:54 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:01 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:07 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:14 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:20 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:27 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:33 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:39 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:46 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:47 2022 user.notice data-broker: data-broker timeout, restart it
Fri Nov 18 14:05:52 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:05:59 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:06:05 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:06:12 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Fri Nov 18 14:06:18 2022 user.warn basicstation[21518]: [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
