I checked the data sheet of the wisgate lite 2 RAK7268C and didn’t see the maximum input voltage, it inly says 12V 1A can someone please tell me what is the maximum voltage we can run on the gateway or hetter yet what is the range voltage it will accept? Reason for the question is i would like to plug it to a solar system with a battery, And the solar charger can push up to 14.1V when the sun is At fullest.
Will it be safe to plug that directly to the gateway? Or will i need to use a regulator if yes which one please ?
Thank you!
