RAK7268CV2, Issue installing OpenVPN
I have already successfully setup 2x Wisgate Edge lite 2 with OpenVPN and no issues.
Now on the third one im having this error when trying to install the OpenVPN app on the gateway.
“There are invalid fields”
Nothing happens after that. What can the issue be?
I have also updated the firmware to 2.2.6.
And i did create the folder as an admin said in another thread but cant see them in the folder inside the GUI but in terminal i can see that they exist.
This is the only thing i get from the systemlog. Would be really happy if someone knows about the problem… Its wierd since the other 5 worked without a problem.
Fri Aug 30 13:30:37 2024 user.err restify: [400, -1] There are invalid fields
Fri Aug 30 13:30:37 2024 user.debug restify: [400, -1] There are invalid fields
Similar issue here… Have about 10 7268V2’s running on a Chirpstack Network Server. Installed new TSL certificates Saturday. 50% of the gateways had no issue. The other 50% Bricked. They require a reset via pushbutton, then reconfigure the gateway exactly the same as it was, and then it works again. Firmware bug, most likely. Currently at the airport to go reset a customer’s gateways, so a very expensive bug.
Yeah did that aswell, didnt work.
So went into it and created folders manually after a 2nd reset then the folders came up, sad with no admins helping here.
