RAK7268V2 Firmware Update - "Error" with "Internal Server Error"
Product = Rak7268v2
Firmware-version = 2.18
Connection = Ethernet cable to my router, with a solid connection to The Internet
Access = Ubuntu-22, Chrome-browser
So far, I have never ever ever been successful at updating this firmware. I experienced the exact same failure a year ago with another gateway (Rak7268cv2, at version 2.20).
Steps:
Additionally, from the gateway, I can “ping” various external Internet servers such as google.com and rakwireless.com . (Diagnostics) >> (Network utilities) >> [Ping].
Additionally, in order to avoid any login timeouts from interrupting these sessions, I always ensure that I initiate these failed firmware updates, immediately after gateway Login.
Additionally, I performed a gateway factory-reset, and subsequently rebooted, and initiating another firmware update immediately after Login. The failure was exactly the same.
Additionally, I have tried several other past firmware versions. These all fail in exactly the same manner. I found these at https://downloads.rakwireless.com/#LoRa/WisGateOS2/History-Version-Release/
WHAT AM I DOING WRONG?
You don’t specify that you are connected to the gateway via it’s wifi SSID when trying to perform the update. If not, try that. Always works for me.
Hi @jonovos ,
I tried several things, and the update was more successful when I accessed the web UI using a static IP address connected via ethernet than when I connected to the gateway’s AP interface, 192.168.230.1.
Could you please share what messages are displayed on the USB serial console during the update?
If [e] and [w] are displayed alternately, the update is progressing normally. If the following screen appears after the update, the update is complete.
Appending jffs2 data from /tmp/sysupgrade.tgz to firmware..
Writing from <stdin> to firmware ...
Thu Nov 20 02:44:14 UTC 2025 upgrade: Upgrade completed
Thu Nov 20 02:44:15 UTC 2025 upgrade: Rebooting system...
umount: can't unmount[ 1277.962892] reboot: Restarting system
 /dev: Resource busy
umount: can't unmount /tmp: Resource busy
[05000C0A][05000C09]
DDR Calibration DQS reg = 00008889
U-Boot 1.1.3 (May 24 2022 - 09:19:12)
Board: Ralink APSoC DRAM:
 Return MAX size!! 0x80000000
My connection:
  • rak7268v2 is connected to ethernet cable.
  • the ethernet cable is connected to a router
  • my Internet is healthy with 1-gbit of service from my ISP
  • I am NOT using the built-in rak7268v2 wifi access point (AP)
  • I am accessing the rak7268v2 through a chrome browser in Ubuntu.
Ethernet has always been more reliable than wifi. In fact, I have frequently experienced poor responsiveness through the built-in wifi access point
  • After I click on [Update], the progress bar slowly increases. Eventually, when it reaches approximately 25%, it immediately vanishes, and a red error message appears at the bottom of the screen.
USB-Console – Nothing appears on the console during this process. It never shows any event. It never shows any error. It remains unchanged. I wonder if there is a log file I should check?
Snip from /tmp/log/20251120141032.log soon after this error:
Thu Nov 20 14:13:43 2025 user.debug restify: firmware copy from:/mnt/mmcblk0p1/tmpbin/tmpdct0r3zk.bin
Thu Nov 20 14:13:43 2025 user.debug restify: firmware copy to: /tmp/rak_rwi_fhw954pp.bin
Thu Nov 20 14:13:46 2025 user.debug "/usr/lib/python3.8/site-packages/flask/app.py", line 1950, in full_dispatch_request   File "/usr/lib/python3.8/site-packages/flask/app.py", line 1936, in dispatch_request   File "/usr/bin/restify/authuser/helper.py", line 64, in do_authentication     return func(*args, **kwargs)   File "/usr/bin/restify/system/views.py", line 78, in upgrade_firmware     raise ex   File "/usr/bin/restify/system/views.py", line 60, in upgrade_firmware     announcement, tmp_file = model.firmware_check(filename)   File "/usr/bin/restify/system/model.py", line 164, in firmware_check     status = _firmware_check_status(filename)   File "/usr/bin/restify/system/model.py", line 212, in _firmware_check_status     return _get_error_code()   File "/usr/bin/restify/system/model.py", line 224, in _get_error_code     content = f.read()
Thu Nov 20 14:13:46 2025 user.debug restify: UnsupportedOperation: not readable
Thu Nov 20 14:13:46 2025 user.info restify: 127.0.0.1 - - [20/Nov/2025 14:13:46] "POST /sys/firmware HTTP/1.0" 500 -
Hi @jonovos
I’d like to confirm whether the issue is with the SD card’s capacity. Can you check all storage devices using df -h in the gateway shell?
Also, could you try upgrading the firmware to version 2.2.1 again?
  • Console output from df -h
root@RAK7268V2:~#
root@RAK7268V2:~# df -h
Filesystem                Size      Used Available Use% Mounted on
rootfs                    9.9M    656.0K      9.2M   6% /
/dev/root                20.5M     20.5M         0 100% /rom
tmpfs                    61.7M      3.2M     58.5M   5% /tmp
/dev/mtdblock7            9.9M    656.0K      9.2M   6% /overlay
overlayfs:/overlay        9.9M    656.0K      9.2M   6% /
tmpfs                   512.0K         0    512.0K   0% /dev
/dev/mmcblk0p1           58.2G      7.2M     58.2G   0% /mnt/mmcblk0p1
root@RAK7268V2:~#
root@RAK7268V2:~#
  • I tried upgrade to 2-2-1 several times. It fails the same way, failing at different percentages. 17.6%, … 22.4%, … 28. xxxx %, …
  • IDEA: Is it possible that a 64gb sd-card is too large??? Should I reduce to a 16gb?
  • Should I re-format it with a different file system? FAT32?, FAT32x?, ext4?
