Is there possibility to connect RAK7271(RAK2287 inside) to TTN without using Raspberry pi, only using Linux machine?
Hello @nedeljkoilic and welcome to the forum!
It is possible to use the RAK7271 with a Linux machine. The guide to install the firmware is found in the RAK7271 docs center.
After creatig the global_conf.json remember to set the corresponding server address and up/down ports in the file. For example:
